02-26-2013, 01:23 AM | #1 |
bb springs and sb springs ?????
How much difference is there between big block springs and small block springs?
Jason '70 C-10 short fleet 427BB TH400 (SOLD) '10 Ford F 350 '13 Ford RAPTOR 6.2 MY BUILD THREAD http://www.67-72chevytrucks.com/vboa...d.php?t=612623 |
02-26-2013, 08:16 AM | #2 |
Re: bb springs and sb springs ?????
Are you referring to front coils? Bbc springs hold up more weight for the bbc. If you put a bbc in a truck with sbc coils its gonna sit the front end down an inch or so. If u put a sbc in a bbc sprung truck its gonna ride kinda rough because they are a heavier duty spring.
-Mike- '94 GMT 400 ext z71 3" body, 3 in rough country, hd mirrors, 20" motometals on 35s |
02-26-2013, 10:50 AM | #3 |
My Carbon Footprint
All I can say is I put my 460 chev in my truck that had a 250 6 cyl and left the stock springs to start with. I swear it didn't move an inch.
02-26-2013, 11:13 AM | #4 |
I assume the previous owner put bb springs in my truck, it was orig. a 6 cyl truck . He had new springs in it when I bought it with a 402bb . I pulled the motor back out and had a few "secret" things done. I put everything back in along with the front clip, the truck sets up like a 4wd. I m trying to figure how much to lower it....
02-26-2013, 11:59 AM | #5 |
My Carbon Footprint
I have ran into this same problem or situation with cars too. Put a BBC in a SBC Camaro thinking it's going to sit on it's knees and it barely moved. I don't think it's nearly the difference we think. Think about it. 5,000 lbs truck and most of the weight is in the front half. Now add or subtract a measly 200 lbs? I realize it's probably a much bigger difference in the hauling capacity rather than the ride height.
It's probably like valve springs. Installed height and open pressures are probably very different. Last edited by prostreetC-10; 02-26-2013 at 12:07 PM. |
02-26-2013, 12:05 PM | #6 |
Florida Edition
Factory BB front springs in a 1/2 ton are stock 3/4 ton springs. I put new 3/4 tons on mine with 1/2 a coil cut off along with 2-1/2" drop spindles. I'm about as low as I want to go with a static drop.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
