Old 02-26-2013, 04:03 PM   #1
hilljob26
hilljob26's Avatar
quadrejet, transfercase mount,blazer tank sender,oil line
i wont need these,time to move em. all these are or best offer
transfer case frame mount, has been blasted and painted,comes with new poly mounts and stock rubber mounts 50 shipped SOLD
quadrejet carb this was pulled from a running driving truck about 4 months ago.. numbers on carb are 1708029 2
1057C0 CY K 50 shipped
oil line 10 shipped SOLD
blazer tank sender, this was only used about 4 months..30 shipped SOLD
21 2500hd duramax
58 apache
HILLJOB GRAPHIX--for all your graphic needs
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=542497
LS ENGINE SWAP INFORMATION THREAD
http://67-72chevytrucks.com/vboard/s...d.php?t=377348
4l60 to an NP205
http://67-72chevytrucks.com/vboard/s...43#post3697343
hilljob26 is offline   Reply With Quote
Old 02-26-2013, 04:18 PM   #2
Oddfire
Oddfire's Avatar
Re: quadrejet, transfercase mount,blazer tank sender,oil line
I'll take the oil line for $10 shipped. Paypal? Jamie 71 Longhorn
Oddfire is offline   Reply With Quote
Old 02-26-2013, 04:33 PM   #3
hilljob26
hilljob26's Avatar
ok, pm sent
21 2500hd duramax
58 apache
My build thread
4l60 to an NP205
Old 02-26-2013, 06:12 PM   #4
UP GRADE
one set closer
UP GRADE's Avatar
I'm interested in the sending unit. Is it in good working condition?
UP GRADE is offline   Reply With Quote
Old 02-26-2013, 06:39 PM   #5
hilljob26
hilljob26's Avatar
it was when pulled,,have no way to test it as of now
21 2500hd duramax
58 apache
My build thread
4l60 to an NP205
Old 02-26-2013, 08:15 PM   #6
capev86
according to the numbers 170-80-2-9-2, that Q-jet is a 1980, 49 state emission legal, auto trans spec carb. the 9 is a hokey number (Rochester didn't always follow their own rules) but we can infer that is a chevy unit by the 90 deg fuel inlet. so you have a good carb there for a driver.....1977+ with all the improvements plus electric thermostat, but it is a fully mechanical carb so an easy install-upgrade on one our classic trucks!
capev86 is offline   Reply With Quote
Old 02-26-2013, 08:25 PM   #7
towbar
towbar's Avatar
Location: Marshall, NC....heart of the Appalachians.....aka, Gods country!!
On the Q-jet, how is the throttle bores, are they worn or sloppy, has the idle mixture plugs been knocked out? and the vacuum pod pull off hold vacuum? thanks
towbar is offline   Reply With Quote
Old 02-26-2013, 11:04 PM   #8
hilljob26
hilljob26's Avatar
doesnt appear to be sloppy or worn, the idle mixture plugs i do not see, just the 2 rectagular heads inside the hole for adjutment, and the vacuum module appears to be working well,,when i pushed it in, you can hear it push air out in the carb,and it came back slower then i pushed it in,,i hope this helps
21 2500hd duramax
58 apache
My build thread
4l60 to an NP205
Old 02-26-2013, 10:35 PM   #9
UP GRADE
one set closer
UP GRADE's Avatar
Ok I'll take it pm me your PayPal
Old 02-27-2013, 01:43 PM   #10
hilljob26
hilljob26's Avatar
ttt
21 2500hd duramax
58 apache
My build thread
4l60 to an NP205
Old 02-28-2013, 11:17 AM   #11
Katrina/10
Katrina/10's Avatar
Do you still have the carb?
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Katrina/10 is offline   Reply With Quote
Old 02-28-2013, 02:04 PM   #12
hilljob26
hilljob26's Avatar
yes,,the carb is still for sale
21 2500hd duramax
58 apache
My build thread
4l60 to an NP205
