Old 02-27-2013, 02:34 PM   #1
k_n_browning
axle??
ok (c10 5 lug)( k10 6 lug) after that is there any other differnts.Thanks
k_n_browning is offline   Reply With Quote
Old 02-28-2013, 01:27 AM   #2
andrewmp6
Re: axle??
c10 is 2wd k10 is a 4x4.
Old 02-28-2013, 01:45 AM   #3
rs74
rs74's Avatar
Re: axle??
What is the reason for your question. That might be able to clear things up a little. Are you looking to switch rear ends or something?
Roy
85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818
1987 R10 shortie
rs74 is offline   Reply With Quote
Old 02-28-2013, 10:17 AM   #4
k_n_browning
Re: axle??
ok yes I am looking at a swap.I have 1968 2 wheel drive that is making alot of noise.
POL make kit to put the 1973-87 rear end into the 1968.My 68 has 6 lugs and I was look for a better gearing 3.73 is way to many RPMs.And There is only two gears for the 6 lug that wouls be a bolt in.3.73 or 3.08.The 3.42 with the tire size that I have would work for the overdrive trans that I am going to put in.Thanks
Old 02-28-2013, 02:13 PM   #5
Keith Seymore
Keith Seymore's Avatar
Re: axle??
Assuming the overdrive you are going to is in the .70 to .73 range, and assuming a "normal" sized tire (P235/75R-15 or so) I would recommend the 3.73 axle ratio.
I would guess the 3.42 is not enough axle with the overdrive (unless you are using a teeny tire).
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 02-28-2013, 02:14 PM   #6
Keith Seymore
Re: axle??
Have you looked into rebuilding your current axle? What kind of noises is it making?
K
1979-1986
1986 - 2019
Old 02-28-2013, 03:59 PM   #7
k_n_browning
Re: axle??
Knowbody that I would trust around here.Rear has a lot of play in it and it growls.After I posted this I found a Calculator Looks like the 3.73s would be better.
