02-28-2013, 06:12 PM | #1 |
402 BIG BLOCK
Garage heater
Here is a cheap way to heat your garage if you have some extra automotive and household parts laying around. It is temperature controlled with a thermostatic relay. It heats a 3 car garage very well. The fluid reservoir on top is to keep the system full so that there isn't any air in the system. The top fan/radiator assembly is hanging from the ceiling above the wate heater.
-40 gal water heater -car radiator -electric water pump -squirl cage fan -duct metal (fan to radiator) -heater hoses -thermostatic relay -reservoir for extra fluid
1967 C10 swb 1970 GMC Jimmy 4x4 2005 Chevy tahoe Z71 2001 Chevy impala |
02-28-2013, 07:01 PM | #2 |
Re: Garage heater
Looks good !!
Is it filled with antifreeze mix or straight water ? I take it that it is an electric water heater. How much a month does it cost to run ? How high are your ceilings ? Total square footage ? Could you elaborate on how you wired the relay ? Where did you obtain the electric water pump ?? Sorry for all the questions,,, but I really like this idea !! Thank You !! Tom |
02-28-2013, 10:46 PM | #3 | |
402 BIG BLOCK
Re: Garage heater
The garage is 30x27 with 10 foot ceilings. I don't notice much of a differnce in my eletric bill, maybe $20 or $30 a month, but thats with running it probably 4 to 5 evenings a week for about 5 hours or so each. The thermostatic releay is like what is used for base board heaters, i use it just to break the ground in the circut.
02-28-2013, 07:37 PM | #4 | |
Old member
Re: Garage heater
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
02-28-2013, 08:57 PM | #5 |
Re: Garage heater
You must of liked the tv show Mc Gyver?????? lol !!!!!!
02-28-2013, 09:52 PM | #6 |
Re: Garage heater
Is it a closed loop?
02-28-2013, 10:52 PM | #7 |
402 BIG BLOCK
Re: Garage heater
It is closed loop. And you could probably get away with a smaller water heater, but free is good too!!
-Radiator was $30 from a radiator shop (fixed for someone and they never picked it up) -squirel cage fan and water heater were free. -water pump was 50 bucks -water heater hose and duct meter were cheap 10-15 bucks -thermostatic relay was i think $15. -maybe 6 hours to put all together.
1967 C10 swb 1970 GMC Jimmy 4x4 2005 Chevy tahoe Z71 2001 Chevy impala Last edited by bcj67chevy; 02-28-2013 at 11:03 PM. |
02-28-2013, 10:54 PM | #8 |
402 BIG BLOCK
Re: Garage heater
Thanks guys!!!
I will post some more detailed pics tomorrow with some more info. A build thread may not be a bad idea jamesi20
02-28-2013, 09:52 PM | #9 |
Re: Garage heater
I like it, must have one of these.
I'm sorry I called you stupid. I thought you knew already. 67 C-20 Custom Camper 68 Nova 396 it does wheelies 2005 Buick Century the one the wife drives 1989 Toyota Tercel to drive when I can't put gas in the first 2. |
02-28-2013, 09:55 PM | #10 |
Re: Garage heater
Thats awesome!
Shawn 1970 Chevy C-10 SWB, 350, TKO 600 5 speed My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881 |
02-28-2013, 10:03 PM | #11 |
Re: Garage heater
I am a HVAC Tech and dont think I could have come up with this contraption......but ofcourse I wold have just installed a decent Air Handler and have the future hopes of AC as well. Anyways, very creative.
02-28-2013, 10:40 PM | #12 |
Re: Garage heater
We need a "build thread" with details...
02-28-2013, 10:57 PM | #13 |
Re: Garage heater
Thank you for the information !!
I believe I am going to build one of these,,, Might try a gas water heater,,,, don't know yet ! How about the water pump ? Brand ? where purchased ? duct meter ????? Tom |
02-28-2013, 11:03 PM | #14 |
402 BIG BLOCK
Re: Garage heater
water pump came from harbor frieght rated at 650 gallons per hour max. is bigge than what is needed, but they didn't have one any smaller that was heavy duty. $50.00
http://www.harborfreight.com/34-hors...ump-69297.html
02-28-2013, 11:07 PM | #15 |
402 BIG BLOCK
Re: Garage heater
The heater came from menards $13.00
http://www.menards.com/main/heating-...354-c-6334.htm
02-28-2013, 11:19 PM | #16 |
Re: Garage heater
Great info !!
What temp do you have the water heater set at ? Tom |
02-28-2013, 11:36 PM | #17 |
Re: Garage heater
I started to build something similar a few years ago, I was going to use a radiator out of a water cooled AC system that was used in a solar powered cabin, it was about 18" square and 8" deep. I was thinking of connecting it to my household gas water heater with a recuirculating pump. The rad had only been used with potable water, unfortunately I needed to climb on something to reach a shelf and stepped on it bending all the tubes!
This has me thinking again! Brilliant idea, how cold is your garage without heat? Do you leave the water heater on or just turn it on when you need it? If so how long does it take to heat up? Will it heat up a 32 Degree room? Thanks! Posted via Mobile Device
http://smg.photobucket.com/albums/v655/aaronhero/ |
02-28-2013, 11:49 PM | #18 | |
402 BIG BLOCK
Re: Garage heater
02-28-2013, 11:56 PM | #19 | |
Re: Garage heater
03-01-2013, 12:06 AM | #20 |
402 BIG BLOCK
Re: Garage heater
Good idea. I will give i a shot. Thanks.
02-28-2013, 11:44 PM | #21 | |
402 BIG BLOCK
Re: Garage heater
02-28-2013, 11:40 PM | #22 |
Re: Garage heater
I just stuff rags in the cracks of the garage door so its nice and air tight and just run the car for a while. Gets nice and toasty but makes me sleepy.
03-01-2013, 12:35 AM | #23 | |
Re: Garage heater
Op, nice idea. If I just had a shop to tinker in this would be a great idea, but since I make a living from my shop I'd better stick to my propane furnace Posted via Mobile Device
1968 chevy lwb, getting ready to join forces with the 70 gmc 1970 gmc swb, getting ready to be a 68 chevy swb 1971 gmc lwb 2500 2wd Sierra Grande 1988 chevy 1-ton crew cab 2wd waiting for a 12v cummins |
03-02-2013, 08:07 AM | #24 |
1969 Custom 30 wrecker
Re: Garage heater
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
03-01-2013, 12:12 AM | #25 |
Re: Garage heater
A bit confused.
Electricity heats water, pump pumps water through radiator, blower blows through radiator. The heat is generated by electricity but instead of directly heating air, you're heating water instead first. Doesn't seem efficient, nor direct. It works, and the cost was low, but are there no electric heaters that heat the air for about the same price? Okay, not 220V ones, but a few 1500W 110V units should do the job too. I'd think it would be a bit less expensive to run too without the water pump, nor the need to raise the temp of the 40 gallons of water up first. |
