Old 03-04-2013, 05:50 PM   #1
dohyde34
peel and stick
Where do you guys/gals get your sound deadener from and what do you get? I went to home depot and lowes and they didn't have any. Also how much do i need? Thanks
dohyde34 is offline   Reply With Quote
Old 03-04-2013, 06:28 PM   #2
MusicMan70
MusicMan70's Avatar
Re: peel and stick
http://67-72chevytrucks.com/vboard/s...=319477&page=2
here ya go
MusicMan70
1961 GMC Suburban
MusicMan70 is offline   Reply With Quote
Old 03-04-2013, 06:29 PM   #3
buckskins4ever
buckskins4ever's Avatar
Re: peel and stick
There a few different makes out there of peel and stick sound deadener. You will have to go to or through a Car audio place to purchase or order online. Dynamat is one of the originals. If you are ok with using a 3M industrial spray adhesive you can go to lowes and they are carrying a new double sided aluminum insulator and deadener by the roll and you can get it in 18", 24", and 36" wide rolls.
buckskins4ever is offline   Reply With Quote
Old 03-04-2013, 07:29 PM   #4
dohyde34
Re: peel and stick
i saw that have you used it? how was it if so?
Old 03-04-2013, 07:36 PM   #5
buckskins4ever
Re: peel and stick
I actually have it inside my doors, on my cab walls, and completely lined the underside of my hood with it. Just remember if you use it, spray both the insulator and metal with glue before sticking. My floor is completely covered with Dynomat.
Old 03-04-2013, 07:01 PM   #6
CrewCab59
CrewCab59's Avatar
Re: peel and stick
Did you look in the hvac section and it's also in the window / door section @ HD
1972 Custom Deluxe 20 4x4 burb
1971 GMC SWB CST 4x4
1972 GMC k20 4x4 (X- brush truck )
1971 Chevy CST Blazer 4x4
1971 Chevy C/10
1970 Cab Chassis C30 157"
1971 Cab Chassis Custom 30 Deluxe 157" 292/4spd ( Napco Replica )
1988 Chevy V30 4x4 wrecker challenger 4812
CrewCab59 is offline   Reply With Quote
Old 03-04-2013, 07:28 PM   #7
dohyde34
Re: peel and stick
didn't look there, but asked a bunch of people. is home depot peel and stick as good as dynamat or comparable?
Old 03-04-2013, 10:55 PM   #8
MidLifer
MidLifer's Avatar
Re: peel and stick
Raammat is very good and cheaper than Dynamat. Whatever you end up buying, take some time to read the information on www.sounddeadenershowdown.com. In brief, you only need to use the metal/butyl stuff on 25-50% of the sheet metal. Anything more than that is a waste, as this material primarily serves to dampen vibration.
For sound deadening, you should put a layer of foam (I used Ensolite) on top of the mat, then finish it off with mass-loaded vinyl (a material used in construction, it is very heavy and therefore not for mail-order, you can find it at local insulation supply houses). The MLV is what really stops sound from transmitting through your cab.
Sound Deadener Showdown explains all this very well (he also sells material).
Here are links to my sound deadening project:
Raammat: https://picasaweb.google.com/lh/phot...eat=directlink
Ensolite Foam: https://picasaweb.google.com/lh/phot...eat=directlink
Mass Loaded Vinyl:
Good luck!
MidLifer is offline   Reply With Quote
Old 03-05-2013, 01:14 AM   #9
Jarwood
Jarwood's Avatar
Re: peel and stick
I used fatmat. They come in a kit with roller and 50sq ft for $79.99. Worked great and covered floor, kick panels, and behind gas tank.
Jarwood is offline   Reply With Quote
Old 03-05-2013, 08:30 PM   #10
dohyde34
Re: peel and stick
nothing over it?
Old 03-05-2013, 10:02 PM   #11
Jarwood
Jarwood's Avatar
Re: peel and stick
Yeah I put carpet over it.
Old 03-05-2013, 01:49 AM   #12
1967chevytruckguy
Re: peel and stick
you can use weatherguard that can come from home depot
1967chevytruckguy is offline   Reply With Quote
Old 03-05-2013, 10:17 PM   #13
Lattimer
Lattimer's Avatar
Re: peel and stick
I've used FatMat a lot for recent audio installs. Its good stuff and works very well. I can usually find a good deal on it on Ebay.
Shawn
1970 Chevy C-10 SWB, 350, TKO 600 5 speed
My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881
Lattimer is offline   Reply With Quote
