03-04-2013, 06:14 PM | #1 |
Speedo off, help
Is there a way to retard or advance a mechanical speedometer? My gears in the transfer case (drive/driven gear) are correct for my tire to transmission but it is off approximately 18-22 % roughly.
If there is a way to adjust the speedo or not I appreciate the input. Thanks, Posted via Mobile Device Posted via Mobile Device
Dan 83 Chevy K10 Scottsdale, ZZ4, TH700r4, 4.10, 33" |
03-04-2013, 06:59 PM | #2 |
Re: Speedo off, help
Yes you can by swapping out either your drive gear, driven gear or both. Your cable should go into your transfer case. There is a site around here but can't find it yet. I'll post back if I find it......
- Jeff 89' K5 Blazer, 2.5" lift, 35" tires 04' GMC Yukon XL, 3/4 ton, 8.1L |
03-04-2013, 07:03 PM | #3 | |
This is why I ask if you can adj the speedo. Thanks for the reply Posted via Mobile Device
03-04-2013, 07:01 PM | #4 |
Here is one website:
http://www.performanceautomatic.com/...ter-gears.html You'll need to first determine what you have (number of teeth) by figuring out the colors of both gears.
03-04-2013, 07:16 PM | #5 |
You might be able to go in and have the speedo re-calibrated but I would suspect that the speedo gears were still off.....don't know.
You could try swapping the easy gear and see if that helps?!?
03-04-2013, 08:37 PM | #6 | |
Thanks Posted via Mobile Device
03-04-2013, 07:17 PM | #7 |
If you are really bored you could convert it to electronic.....but that's a whole other subject! I did it and now my speedo is spot on with 35's.
03-04-2013, 08:36 PM | #8 | |
On a side note; what is involved in the conversion? Thanks Posted via Mobile Device
03-04-2013, 10:29 PM | #9 | |
http://coloradok5.com/forums/showthread.php?t=296187
03-04-2013, 07:53 PM | #10 |
When I first read the title, a very disturbing image popped into my head.....
Max Max's bagged 81 81 rcsb bagged, 22s, build in progress 09 ext cab, 24" U2's, DD sub/amp |
03-04-2013, 09:51 PM | #11 |
Get a ratio adaptor.
http://www.transmissioncenter.net/sp...____va.htm#350 |
03-04-2013, 11:05 PM | #12 | |
I like to throw an adapter on there; it "skips directly to the answer" instead of doing all the intermediate mathematical steps. The last time I did this the adapter I needed was laying on the workbench (no purchase necessary). K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
