Old 03-05-2013, 10:54 AM   #1
jlah69
VIN# locations on a 69 GMC
I was wondering where the vin#'s would be located on my 69 GMC C15. I know the tag in the driver side door opening, but are there any other places? I'm wondering because I'm thinking about swapping to a different cab that has less rust and I'm not sure how that would work with multiple vin#'s. Thanks for the help.
jlah69 is offline   Reply With Quote
Old 03-05-2013, 11:29 AM   #2
jpmanyhearts
frankenstien Fabrications
Re: VIN# locations on a 69 GMC
i think they are located in the driver's side door jamb on the vin plate, also on top of the drivers side frame rail next to the engine and last but not least, it should be on the glove box option sheet.
frankenstein Fabrications
jpmanyhearts is offline   Reply With Quote
Old 03-05-2013, 12:02 PM   #3
Livrat
Member #1049
Livrat's Avatar
I have found that not all GMC's had a vin on the frame, but if it does it will be on the driver side frame rail (on the top) just behind the steering box and one midway under the cab
Livrat is offline   Reply With Quote
Old 03-05-2013, 12:12 PM   #4
ChevyCruizer
17's too small
ChevyCruizer's Avatar
Pictures. Not mine but from other threads on this forum.
68 C10 SWB SS 5 lug power disc brake conversion 2.5 inch drop spindles van tilt column Air Ride Technologies Cool Ride air bag kits Performance Online tubular upper control arms and shock relocator kits ECE super track panhard bar 1 piece side windows
ChevyCruizer is offline   Reply With Quote
Old 03-06-2013, 12:07 AM   #5
jlah69
Thank you for the info.
