Looking to bag my 72' C10
I have a 72 longbed. I've been really into the bagged trucks for a long time. Used to have a bagged s10. But i'm thinking about putting bags on my c10. I have several questions for this though. I'm not sure exactly who to message about my questions.
Do they make bolt on c notch kits?! That would include everything for the back. Bags, Mounts, Everything. Who would the manufacturer be that carries the bolt on kit? Also looking for the kit for the front, would it be the same manufacturer? I don't really want to "z" my frame to be honest. Thanks in advance for any information about this. |
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: Looking to bag my 72' C10
Look here,...
www.porterbuiltfabrication.com
Do you have any experience with any of these kits by chance?
#4 | |
I consider Porterbuilt the best C10 lowering (static and air ride) products that you can buy.
You can look at my build thread, I have their kits. you can get stuff cheaper, Like a CPP notch is about half the price, but the Porterbuilt stuff is better quality.
=MATTHEW 69 Stepper...Stroked & Bagged ![]() 2003 Chevrolet Z71 Ext. Cab 1995 Cavalier gas saver! |
Sweet. I'm definitely going to go with porterbuilt I'm not wanting it to lay frame or anything like that, so no going way over the top. Anyone know how low the stage 2 basic kit would allow me to sit or what the ranges of heights are lowered and raised by chance?
Your height is going to depend on other factors, too, like tire size. With a 27" tall tire, my crossmember is about 2" off the ground. That is with the stage I front kit (plates, cups, bags, shock relocators) and 2.5" drop spindles. The front sits slightly lower than the rear when fully dumped, but the axle touches the top of the notch in the rear. In my experience, you won't know EXACTLY what you'll get until you have it installed. The numbers seem to vary (slightly) from truck to truck. I'm happy with my dumped height, and fully aired, I can go on up higher than stock height. My ride height is probably similar to a 4"-6" drop. I have been really happy with the Porterbuilt stuff. It is extremely well made. It isn't cheap, but it's not made cheap, either, and they have done all the research, so if you install their kits like they say to, you are basically drilling and bolting, which was good for me as a first time bagger. I would definitely use them again.
Also i was lookingh at the stage 1 here kit for the front. Is that the kit you used cubber? If not does anyone else know how thatd work with the stage 2 rear. Really want my truck to sit level overall once i install kits like this. But not sure if i can achieve that with the front stage 12 kit and the rear stage 22 kit. Or should i just call porterbuilt and ask them
Posted via Mobile Device |
Yes. I used the stage 1 up front.
It depends how low you want it and wheel size.stage 1 front and stage 2 rear will get you pretty low with out cutting up the bed.
The Stage 1 kit and Stage 2 rear do go together well. We have our Pro1 kit we put together using these 2 Porterbuilt kits. We then include our Pro2 air management that uses dual VIAIR compressors, 4 gallon tank, AccuAir VU4 valve, etc..... The truck will sit fairly level with this system, of course depending on your wheel size and tire heights.
http://www.azproperformance.com/Pro1...r-Bag-Kit.html ![]() |
Porterbuilt quality is well worth the money and the wait. If you can't get it save up because you won't regret it. Plus if you decide down the road that you want to go lower you won't have a problem upgrading or selling what you got.
LIFTED OR LOW THE ONLY WAY TO GO!!!! Check out my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=517346 Projects 56 Chevy pickup Porterbuilt FR/RR dropmembers |
Im definitely gonna save up for porterbuilt. That kit looks well worth the money and wait. Definitely be trimming some spending to get this asap. Thank you all for your help! Its amazing to have a forum like this where everyone is willing to help and talk. Thanks guys
That ProPerformance kit is a good deal!
#15 |
We will love some before and after shots once you get it bagged.
#16 |
Oh believe me there will be a lot of pictures haha. I will definitely post some on here.
#17 |
Porterbuilt street rods.com
