1965 K-10 4x4 lift kit?
I have a 65 K-10 navy issue Stepside 4x4 that I need to lift about 4inches. Since the lift isn't made aftermarket I'm trying to see what others are doing here. This particular truck has a factory block lift already in the rear but want an all spring lift rather than any blocks. I could have springs made but want any suggestions from those who have done the lift and what obsticales they faced.
Posted via Mobile Device |
#2 | |
![]() Join Date: Sep 2012
Re: 1965 K-10 4x4 lift kit?
Posted via Mobile Device Posted via Mobile Device |
60-66 Nut
I'm afraid you will likely have to do what travz500 and jonzcustomshop have done. That is convert the truck to the '73-'87 suspension, which have lift springs available. Something similar that can be done is to use the 52" spring conversion brackets on the front and a shackle flip on the rear, with about 4" springs, and you should be close to 8" of lift.
http://www.diy4x.com
