Some help indentifying dropped spindles
![]() ![]() ![]() No name or part # just c10 lh and rh |
Re: Some help indentifying dropped spindles
If that is a bell to the lower left of lh or RH it's Belltech.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
#3 | |
67-72 parts collector,…
![]() Join Date: Nov 2002
Belltech has the word "Belltech" and the part number cast into each spindle. Posted via Mobile Device
[QUOTE=lolife99;5932408]Not true.
Belltech has the word "Belltech" and the part number cast into each spindle. Posted via Mobile Device[/QUOTE Bought my Belltechs and that bell was the only marking. They were bought years ago but the rust on those would say same time frame. Posted via Mobile Device
Looks like DJM or Chassis tech to me.
Eric Evans Queen City Shop Truck http://67-72chevytrucks.com/vboard/s...34#post6139834 66 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=543110 |
You'll have to check upper balljoint or outer tie rod fit to know for sure what year spindles these are.
kind of figured.....Ball joint position is 12/6
Watch out for your cornhole !
![]() Join Date: Jun 2003
What Keith means is that you're going to need to go to the parts store with the spindle and test fit ball joints and tie rid ends to find the ones that fit the tapered ball joint and tie rod holes. It could be 63-70, 71-72, or 73-87 fitment. All will work on your truck if you swap parts accordingly.
Posted via Mobile Device |
I know.....thanks. Thought I remembered the older spindles were laid back a little on the caliper location moving the ball joint orientation from 12/6 oclock to 11/5 which is why I included that. Don't remember if that is correct or not.
He is correct
That means they came from the Bell foundry. They cast spindles for different companies as well as Belltech stuff. They also cast the Super Bell axles for hot rods too.
Its the same thing as Western casting spindles for CPP, Early Classic, as well as themselves. Posted via Mobile Device |
Very cool learn something new every day. heading to parts store now....see what I can find out.
73-87....Don't know the brand, but knowing they came out of Bell foundry I am more comfortable....
There are two 73-87 spindles.
Light duty 1" rotor version and the HD 1-1/4" rotor version. Posted via Mobile Device
