Anyone run CPP 4" rear HD drop springs?
I currently have a pair of ECE 4" drop springs in the rear of my '64 panel. I like where these springs put me stance-wise, but they seem a little too soft for hauling much around. I have a boat and gear I like to take on trips occasionally. With everything loaded up, I'm nearly on the bumpstops.
I found out CPP offers 4" springs in a 'heavy-duty' variant. Anyone use em before? Are they truly more 'HD' than the regular springs? |
![]() Join Date: Jan 2012
Re: Anyone run CPP 4" rear HD drop springs?
Are yours really the HD ones?? The first ones that I bought from ECE were NOT HD... I sent them back and they send the right ones to me.. (yes--I asked for the HD ones when I made the original purchase..) Both sets look entirely different in the spring thickness and their obvious weight.
My '65 Suburban Resto build-- http://smg.photobucket.com/albums/v6...65%20Suburban/ And it's story of being 'saved' http://www.jalopyjournal.com/forum/s...d.php?t=631495 |
We tried a set of CPPs 4" drop HD rear springs in our burb...pretty much was at the bumpstops when ya put a foot on the bumper
![]() Stock on the left, HD 3/4 ton PU rear springs in the middle (what we're running now), CPP 4" drop HD springs on the right...
1958 Chevy 1 ton dually 4X4 dump/flat bed My build thread 1966 "Not-So-Original" Chevy Custom Trim Suburban My Time-Killing Project Truck 1966 GMC Extended cab 1 1/4 ton 4X4 My Son's build thread |
I don't think those on the right are HD--those are the same ones I originally got before they exchanged em for the middle ones--HUGE difference
Oh wow. Surely those don't both give a 4" drop? The ones in the middle must be stock height 'HD' springs? Hard to know.
Active Member
![]() Join Date: Aug 2012
Contact Coil Spring Specialties in St. Marys, Kansas. I have first hand knowledge that they supply several of the vendors with their springs.
I have talked to them about towing with a lowered truck. I was told that my best bet would be a two stage spring. By dealing with the manufacturer, you can get exactly what you need. They will build a spring that will work for a specific application, and you can buy direct from them. |
![]() Join Date: Aug 2004
I have 4" drop springs and I can tow my trailer...slowly, so now I am putting air bags on the rear for the towing adjust ability.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
I was just about to suggest airbags out back but Clyde65 beat me to it.
