Need help
I was wondering if anybody has ever put down replacement carpet. I put down the underlayment and got my holes cut in it for the seat, seat belts, and dim to bright switch. I was wondering how you went about cutting those holes for the seat, seat belts, and dim to bright switch into the carpet. Any help would be great thanks guys.
1972 Chevy C20 Pickup 1974 Plymouth Roadrunner 2009 GMC Sierra 2011 Chevy Equinox |
Re: Need help
I used ACC carpet it had the dimmer switch hole reinforced and cut already. And the seat belts I simply removed them used a ice pick located the holes from under the cab making a hole to get the spot to reinstall the bolt into the belt. Same with seat bolts.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
the boat guy
Re: Need help
Razor for big holes, soldering iron for small holes.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
Re: Need help
A soldering pencil works great.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
![]() Join Date: May 2010
Re: Need help
There is an installation video on either ACC's or Stock Interior's (sells ACC) website that suggests using a hole saw IN REVERSE for the holes. I located where to put the holes with an ice pick as Sammy suggested above. Then I used the hole saw as in the video for the actual hole. It worked great. I believe I used a 3/4" hole saw (in reverse!). My carpet was ACC with the mass backing.
Re: Need help
what about glueing it down?
Re: Need help
No, not unless there is a specifc need.
Re: Need help
just seems like it don't want to lay to flat.
