Old 03-08-2013, 02:15 PM   #1
melhilburn
melhilburn's Avatar
my dash lights burn out
Ive dealing with this with no luck -I have a 64 with the original wiring harness - my dash has guages - My blinker lights work no problem - But when I replace all other dash lights they burn out in less than an hour??? - I have installed a ground with from the back of the dash to the brake pedal structure - Adny ideas what could be going on???
melhilburn is offline   Reply With Quote
Old 03-08-2013, 02:36 PM   #2
71K20chevy
71K20chevy's Avatar
Re: my dash lights burn out
What bulbs are you using? Typically 168 bulbs give the most light without putting out TOO much heat.
71 K20
64 GMC mud truck
71K20chevy is offline   Reply With Quote
Old 03-08-2013, 08:43 PM   #3
1963c-10
1963c-10's Avatar
Id check and make sure the right fuse is in there also. Real common to find PO's just throw in whatever they had laying around. Might not hurt to check the connection where the cluster and main harness meet also.
1964 Short bed trailer
Old 03-08-2013, 10:25 PM   #4
MacsGTO
It's going to be a grounding problem. I would check all of the light buckets and make sure nothing is corroded or shorting out to the panel housing. Plus make sure whatever grounds you already have are connected tightly and are on bare metal that is clean. Your power is dumping into the lights themselves and without a path to follow it's causing them to burn out.
MacsGTO is offline   Reply With Quote
Old 03-08-2013, 10:29 PM   #5
jonathan-m
This is correct, I had the very same issue. I would replace bulbs and they'd burn out on the first drive, turned out to be grounding issues.
Rockin' a '66 and loving every minute of it
jonathan-m is offline   Reply With Quote
Old 03-09-2013, 07:00 AM   #6
melhilburn
melhilburn's Avatar
Cold you help me with a simple grounding solution - electric is my weakest link - Never have figured it out
Old 03-09-2013, 08:25 AM   #7
MacsGTO
Sure. Do you have a wiring schematic already? If not do a search on here and you'll find one. They are readily available. That will be step one. Let us know when you're ready for step 2.
Old 03-09-2013, 09:20 AM   #8
melhilburn
melhilburn's Avatar
ok wil do - It will most likely be after 1:00 pm today
Old 03-09-2013, 04:29 PM   #9
melhilburn
melhilburn's Avatar
ok I found a 1964 color wiring diagram
Old 03-09-2013, 07:04 PM   #10
TBONE1964
Cluster King
TBONE1964's Avatar
Do you have a volt meter? Can you check voltage (engine running) athe battery post and see what you get.
If it is over 14 volts, then your voltage regulator may be stuck and overcharging the battery. This is not something that dash light like.
If your wiring is good and grounds are clean and tight then an over voltage issue may be what you are looking for.
Just my thoughts.
TBONE1964 is offline   Reply With Quote
Old 03-10-2013, 04:34 PM   #11
melhilburn
melhilburn's Avatar
I think the problem is the dash lights I have been installing are 7 volt not 12 volt - I just discovered this today - will try to find the correct lights and report back,
Old 03-10-2013, 05:06 PM   #12
'63GENIII
'63GENIII's Avatar
That will defintely give you the results you are getting. Once you have the right voltage bulbs, I'm certain they will last longer
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 03-12-2013, 05:24 AM   #13
melhilburn
melhilburn's Avatar
Well looks like I've soved the problem - thanks for all the help - I wold like to learn how to work with a wiring diagram so any hints you can give me please let em fly
Old 03-12-2013, 05:26 AM   #14
melhilburn
melhilburn's Avatar
My dome lihgt still isn't working - I have no idea what the probelm is - if I put a jumper on it the bulb is good? - Cold I just have a bad light swith?
Old 03-14-2013, 01:45 PM   #15
luvbowties
luvbowties's Avatar
Smile Re: my dash lights burn out
Could have. With battery connected & bulb removed, test each bulb-terminal for volts--one should have 12 volts at all times. The knob on the switch merely controls and supplies ground to the other terminal. If you have volts at one terminal, insert bulb and ground the other terminal: if bulb is good, it should light up.
hth,
sam
luvbowties is offline   Reply With Quote
