Old 03-08-2013, 04:55 PM   #1
blazins10
blazins10's Avatar
60-63 side glass
im looking into new glass for my 63 , what glass should be in it ? theyre asking with or without metal frames i dont have either so what should i go with? i prefer without so does the mean i can just buy it for the without frame option
thanks guys
///Relaxed Atmosphere
blazins10 is offline   Reply With Quote
Old 03-08-2013, 05:05 PM   #2
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Re: 60-63 side glass
63 light duty trucks came with the side glass without a metal frame surrounding the perimeter. 1963 Medium and Heavy Duty had a metal frame around the perimeter.
Old 03-08-2013, 05:07 PM   #3
blazins10
blazins10's Avatar
sweet !!! thanks
Old 03-08-2013, 08:31 PM   #4
Greg63
Enjoy your truck
Greg63's Avatar
I always wondered why some glass had metal and some didn't.
Thanks for that.
Greg.
1 Corinthians 10:13
1963 Chevrolet 1/2 ton
2010 Camaro SS/RS
2014 Jeep Grand Cherokee
2016 Jeep Cherokee
Greg63 is offline   Reply With Quote
Old 03-08-2013, 05:07 PM   #5
markeb01
Senior Enthusiast
markeb01's Avatar
I believe you can use either glass, but need the corresponding felt channel in the door. My 1960 has the metal frames which are roughly 3/8” in width. The felt channel in the door has a gap or slot about ½” wide. If there are no frames the felt channel would be close to the thickness of the glass alone.
From what I’ve read in the past, framed glass was made of safety plate (like a windshield) whereas non-framed side windows were made of tempered glass. Although over the years I had plenty of old cars without framed windows and I always had new flat glass cut by a local glass shop out of safety plate. They just sanded the edges smooth.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 03-08-2013, 05:16 PM   #6
blazins10
blazins10's Avatar
thanks guys , i have to order a weatherstrip kit and new glass
so it just makes it easy
Old 03-08-2013, 05:26 PM   #7
aerotruk63
aerotruk63's Avatar
I took all of my original GREY GLASS to the glass shop and they used them as templates to replicate them in GREEN TINTED, EASY EYE SAFETY GLASS. The windshield had been replaced in my truck before I purchased it and had the EASY EYE GLASS . The original door glass and back window was Grey. The tinted glass, RPO A11, was an option originally and usually installed in Air Conditioned trucks. When the sun hits a reflective object a little starburst is reflected. I originally thought there was a storm front following me on a sunny day. lol
Old 03-08-2013, 05:30 PM   #8
1963c-10
1963c-10's Avatar
My 63 has non-framed glass. Im converting my truck to framed glass as I like the chrome around the glass. The swap is easy, just have to get the correct weatherstrip for it. Thats why they ask framed or not. The framed glass I have came out of a 61 c-10 short fleetside.
1964 Short bed trailer
Old 03-08-2013, 06:04 PM   #9
theastronaut
theastronaut's Avatar
The only problem with framed glass is the paint or chrome eventually gets worn and scratched from sliding in the track, paint does it worse than chrome.
theastronaut is offline   Reply With Quote
Old 03-08-2013, 07:19 PM   #10
blazins10
blazins10's Avatar
the truck shop sells the vent windows for 16 ea and the side for 35 ea , i already got new front and rear glass , the weather strip kit is 185 $
Old 03-09-2013, 01:16 PM   #11
61K10
61K10's Avatar
the bottom channel plate that the window sits in is different between the two types. probably could use the frame ones with non framed glass but not the other way around.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
