03-10-2013, 05:15 PM | #1 |
Final verdict on electric fans?
Hey all,
I have read all the different threads I have found on electric fans with stock 4 core radiators. I've seen to use the Taurus fans, maxima fans,windstar fans, jeep Cherokee fan, even the HHR fan. My question is this: which one of these has actually been used successfully for any length of time. This will be used with a 6.2 ls motor, so not sure if it needs more cooling or not. I have the stock dual electric fans from the donor vehicle, but it will take some work to make it fit. I'm looking for easier but not crazy expensive. Also, can I go with new aftermarket fans? Are they reliable? They are only about 80.00 on eBay for dorman fans. Thanks for the input all! Shawn Posted via Mobile Device
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
03-11-2013, 12:41 AM | #2 |
Truck and auto performance nut
Re: Final verdict on electric fans?
another option....and made for our trucks. I have a 4 core radiator on my 6.0 fitted with a Old Air Products dual electric fan system for our radiators. Came with relays and all, including thermostatic control and radiator probe to run w/o ECM control but can also can be controlled by an ECM. Can't remember the cost...seems I bought thru ECE or Brothers or similar? Mounts up like it should too.
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
03-11-2013, 12:42 AM | #3 |
I looked at that one. Just a little pricier than I really want to spend on a set of fans. Very nice, but a little expensive.
03-11-2013, 03:24 AM | #4 |
I would go with a factory fan like the Taurus or Windstar, they are usually bulkier but pull more air than the cheaper aftermarket fans. In a truck space isn't at a premium they work well and are quieter. I can't stand the sound of a loud fan that makes your car sound like a jet taxiing down the runway! The higher quality fans arent as loud, so you get what you pay for. Ive seen some real nice street rods that look good then you see them driving with that noise, just ruins it for me.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
03-11-2013, 09:01 AM | #5 |
Boosted Member
It's not in a 67-72 truck, but on a past swap project I used dual fans from a Dodge Intrepid.
I TIG welded bosses to the radiator tanks so that the Intrepid fan was able to bolt up to it. Been running for a year now, most of it in the Texas heat...zero problems.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2023 Ford Explorer ST - Twin Turbskis 2023 Ford F150 RCSB - Whipple Supercharged 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
03-11-2013, 07:26 PM | #6 |
I used fans off of a 2001 LS1 Firebird... That fit well, and have a lot of air flow.
Mark ----------------------- Crash's 69 4x4 SWB Crash's Roof over Lake Home Crash's 1988 Land Cruiser Build |
03-11-2013, 08:32 PM | #7 |
meowMEOWmeowMEOW
I would consider looking for a used or ebay/craigslisted aftermarket unit, especially if you are not running air conditioning.
Reason I say this, many of the better quality aftermarket units flow more air on a single fan, and without the a/c on many of the twin fan setups only run 1 fan at a time (I'm sure many of you bypassed this). Aside from that, a larger single fan from a good company may draw less amperage; due to a better quality motor/bearings/blade design. Thats my 2 cents, my be-cool fan and radiator have been through a 355 and now my 6L flawlessly.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
03-11-2013, 08:42 PM | #8 |
Thanks for the input guys. The ls1 fan looks pretty good. That's very interesting about the aftermarket fans. I think I would like to run dual fans since I'll be running oth the front and rear AC in the big ok burb.
Posted via Mobile Device |
03-11-2013, 10:28 PM | #9 |
I live in the Mojave desert and run windstar fans, with just one running it kept my truck at temp idling on a trail in 110 degree weather. They pull some air.
03-11-2013, 11:26 PM | #10 |
I'm really leaning towards the windstar fans. What year did you use? I was looking at the 99-03 or the 95-98? They look the same. Is there a difference or a preference between the two?
03-11-2013, 11:32 PM | #11 |
I don't know if there is a difference, but I'm pretty sure they are from a 98, I got them used at the wrecking yard.
03-12-2013, 12:14 AM | #12 |
And they mounted up easily? Looks like they really cover the radiator well.
03-12-2013, 02:51 AM | #13 |
Collector of Projects
MoTech that does 6.2L swaps into Jeep JKs, swears by the Lincoln Mark VII fan... They run a custom aluminum radiator that has to be small to fit the Jeep and they all run the factory AC as well. The Lincoln fan is a true 2 speed fan with a dual wound motor, where other 2 spped fans use a resistor to cut down the voltage for low and full voltage for high.
I found a dual speed Grand Cherokee fan that will fit in the our factory fan shroud. I hope it works well. I bought it new on eBay for $100. Fan shrouds are almost as important as the fan itself. If your shroud doesnt direct all the air throught the radiator, you are reducing the effectiveness of fan. |
03-12-2013, 02:56 AM | #14 |
That was the other fan I couldn't remember. The Lincoln Mark VIi fan. I wanted to do the Cherokee fan as it would seem to be the easiest install of all, but my understanding is that it doesn't fit in the big block shroud correctly. I don't know, maybe I should just get a sbc shroud. That is of course more money and more work. Wasn't there a particular year (1 year only) Cherokee that had a two speed single fan? I think I remember 1995 or something?
03-12-2013, 03:08 AM | #15 | |
I THINK this is the fan... but dont quote me on it as I dont have the original in front of me... http://www.dormanproducts.com/p-2234...Fan%20Assembly |
04-25-2013, 07:49 PM | #16 | |
So, regarding fans you should check out Hollister Road website. They sell relays and have worked with several types of fans. Even have nice write up on running aftermarket fan in 67-72 Chevy. Spoke with Dave, very friendly and helpful man. Recommended I get TYC PN 620950 from RockAuto. This is a 2 speed 94 Tbird fan for $63.79 brand new. If a plug is needed Hollister sells one for $20 and the fan relay kits range from $60 - 70. In my case the PCM from the LQ9 should control the speed. Some modification is required (trimming shroud) to clear front of motor. |
04-25-2013, 10:07 PM | #17 |
Addicted to Rust
I have the Mark VIII fan in a stock big block shroud. Using two 70 amp relays for control. No problems in approx 12k miles. Jay
http://67-72chevytrucks.com/vboard/s...d.php?t=425728
Current trucks: (48 GMC100 320 inliner) Gone (48 Suburban in pieces) Sold 87 GMC CCSB 5.3 4l60E Daily Driver ECTA National record holder XO/PP We never really grow up, we just learn how to act in public. |
04-26-2013, 11:34 AM | #18 |
17's too small
i like a dual fan set up and if you wire it like a stock Fbody LS1 then both fans work and give you a low and high fan speed. years ago i had a set of fans that only had the high speed and it really whined loudly all the time.
ls1nova71 (i think) has a thread somewhere on here that has the wiring schematics
68 C10 SWB SS 5 lug power disc brake conversion 2.5 inch drop spindles van tilt column Air Ride Technologies Cool Ride air bag kits Performance Online tubular upper control arms and shock relocator kits ECE super track panhard bar 1 piece side windows |
