rally wheel paint question
Does anyone know if the rally wheel paint LMC sells is any good? I'm only questioning because the last few things I got for my 85 from LMC kinda sucked and when I'm paying the kind of prices they ask I expect a little quality is all.
Robert Olson Transport
![]() Join Date: Oct 2002
Re: rally wheel paint question
I have used the wheel paint in the regular chain auto parts stores and never had a problem its also a lot quicker to get more if you need or return what you dont use
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
![]() Join Date: Dec 2012
I used to buy paint at the local NAPA store color was called import magnizium was correct color
1946 car hauler 1948 surburban 1937 chevy sedan 1940 olds sedan (project) 1967 ss396 chevelle 1999 dually crewcab(24000 miles) |
Rattle can stuff from your local auto parts. Easier to get more if touch-up is ever required. These days, I've been using VHT hi-temp header paint for Ralleys (truck & car). Flat Aluminum w/VHT satin clear....
I used VHT SP188 argent silver the last time I painted the wheels. Then I used their clear coat over it. Turned out great for me.
Jeramy '84 GMC project truck '85 Chevy 4X4 SOLD '07 Chevy Trailblazer SS 5th Annual SHPHC Car/Truck Show Pics http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT |
I used dupli-color silver metallic. Also put a few light coats of clear. Got it at oreillys.
1979 ![]() 1996 Silverado x-cab "the daily" |
buffle
I use Krylon dull aluminum , works and looks good.
Life is like a roll of toilet paper. The older it is, the faster it is used up. |
I did use the Krylon but the Dull Alum has been difficult to find easily on the shelf. Every time I went to buy a can, it was not to be found (in my area).
I saw the VHT & tried it. IMO (having used both) the VHT has much better coverage & appears the same. If you run into the same issue w/availability, you might try the VHT.
I used Rustoleum and Krylon.
http://67-72chevytrucks.com/vboard/s...d.php?t=522012
Willie Swamp Angel Truckers '72 C10 Highlander ![]() People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't. ![]() |
