Old 03-12-2013, 03:56 PM   #1
PAPA KENT
PAPA KENT's Avatar
Replacing axle seal on my 62
i'm in need of some information regarding replacing my axle seal on my 62 1/2 ton. i've been into alot of fords through the years but not one of these old style 62 diffs. does the axle retainer unbolt from the backing plate or do i remove the rear cover or take the 3rd member out to pull the axle. i figured i better ask first so i can purchase the gaskets i need before tearing it down.
thanks.
PAPA KENT is offline   Reply With Quote
Old 03-12-2013, 05:41 PM   #2
markeb01
Senior Enthusiast
markeb01's Avatar
Re: Replacing axle seal on my 62
Assuming the 1962 rear end is the same as a 1960, the following pages from the 1960 Chevy Truck Shop Manual may prove helpful:
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 03-12-2013, 10:31 PM   #3
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
hey, you should come check out that rear in the 61 out at my place before you put too much work into this one- if it will work, you might just want to do the swap instead...
Old 03-13-2013, 12:01 AM   #4
PAPA KENT
PAPA KENT's Avatar
mark thankyou very much for the great pictures and explanations.so they are pretty much like the chevrolet passenger cars up to the 80's.
thanks so much for your input.
kent.
Old 03-13-2013, 12:06 AM   #5
PAPA KENT
PAPA KENT's Avatar
hi jon, yes i was thinking about that tonight. i have a appt to get the 62 aligned at 10:00 am tomorrow,if your going to be out there around 9:00-9:30 or so i will meet you there. that would be a much simpler way to get the job done and to do whats needed anyways.if not i'll call you tomorrow and we can set up a game plan.
thanks jon,
kent.
