Old 03-12-2013, 04:54 PM   #1
jorgensensc
jorgensensc's Avatar
Need quick help identifying electric fan.
Sorry for the dire sound, but I found an electric fan on Craigslist for 50.00. Guy says it is a 2 speed mark7 fan. Pulled it out of a 97 Lincoln. I'm confused because it has a white plug and 3 wires, red, blue, black. I thought all the two speeds had 4 wires and a black connector. Should I buy this or not? Is it the right 2 speed fan? I need a high and low since I have ac. I've read some used variable voltage to control the fan, is this one of those? Im suppose to go get it in 2 hours. Thanks for the last minute help!
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 03-12-2013, 04:57 PM   #2
jorgensensc
Re: Need quick help identifying electric fan.
Pic of the fan.
Old 03-12-2013, 08:23 PM   #3
Sammy
If it actually came out of a 97 Lincoln it would be a two speed fan because of the AC and only one fan. Like you I would have figured another wire unless the Lincoln has a relay that kicks in causing the higher speed when the air is on.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 03-12-2013, 08:32 PM   #4
jorgensensc
Thanks for the input guys! I went and checked it out. It is a variable speed fan. Won't work for me without a controller, which I don't want to buy if my ls computer will control a 2 speed fan.
So this is what I figured out about mark VIII fans:
White plug with inspection port----single speed
White plug without inspection port---- variable speed
Black plug---------2 speed
Hope this helps out somebody else.
Shawn
Old 03-12-2013, 08:33 PM   #5
Sammy
Just looked at a close up pic of a push pull fan on Jegs. It has only two wires into the fan and it is a single speed fan. So the three wires would give you a high output lead, low, and a ground. Sounds like that is what you are looking for.
Old 03-12-2013, 08:36 PM   #6
jorgensensc
Not quite Sammy. That's what I thought. For some reason there is a third wire that terminates inside the wiring harness and doesn't actually go to anything on some single speed fans. Goofy right?
Old 03-13-2013, 08:38 AM   #7
Sammy
Agreed logic doesn't work here. hmm. Maybe on the Lincoln they had too many 2 wire connection plugs n decided to make it idiot proof then.
