Old 03-13-2013, 06:13 PM   #1
Chelmore
New 69 Chevy C10 owner
I just purchased a 69 Chevy C10 LWB Fleetside with a 307 engine, and 74,000 miles on it. It sat in a garage for a long time. The first issue I want address with it is that it is hard to start first thing everyday. Once it has been running a while it starts fine (electric choke issue?). The second thing is that when it is running it dies when I press on the gas unless I get into it pretty hard or pump the gas pedal. This happens in park or while in gear. It idles perfectly. Any ideas?
Chelmore is offline   Reply With Quote
Old 03-13-2013, 06:46 PM   #2
Mister-B
Re: New 69 Chevy C10 owner
When I start mine, I pump the gas pedal twice before turning the key, and then sort of lightly tap it as I'm turning the key. If I do this, it usually fires right up. The exception, is when the weather is colder or warmer than when I adjusted the idle on the carb last. Also, don't use premium unleaded. Too rich
Mister-B is offline   Reply With Quote
Old 03-13-2013, 06:52 PM   #3
Chelmore
Thanks A.J. That is interesting about the fuel. The previous owner did run Premium. That is what is in it now.
Old 03-13-2013, 06:55 PM   #4
Mister-B
Well, when I bought mine last year I put 91 octane premium in it, since that's what my newer vehicles call for, and it ran lousy on it and was more expensive. The general consensus on here, is that just regular unleaded is best
You'll probably want to adjust the idle too, since the weather is starting to change. If you search my oldest posts, you'll see a thread on what octane to use and one on how to adjust the idle, where other guys helped me out
Old 03-13-2013, 06:54 PM   #5
big bad orange
big bad orange's Avatar
First off welcome to the board!
now as for the gas problem I would change out the fuel filter and give it a good tune up, plugs, wires, points if you dont have hei.
just like that old Johnny Cash song. "One piece at a time and I am go na make an old C10 mine a look at all your faces when I drive through your town"
big bad orange is offline   Reply With Quote
Old 03-13-2013, 07:28 PM   #6
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Sounds like the accelerator pump is bad in the carb, probably from sitting. Take air cleaner off and with the engine OFF look down carb and move throttle slowly should have smooth steady stream of fuel. If not rebuild carb.
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 03-13-2013, 08:18 PM   #7
msgdsrf
May also be just too much choke. Look at choke position at start up, after you set it with a little throttle.
msgdsrf is offline   Reply With Quote
Old 03-13-2013, 09:21 PM   #8
ole dollor
ole dollor's Avatar
welcome to the forum from Texas, like others have said look over the tune up items and check carb choke, might just be points are burnt a little. good luck on your truck...
ole dollor is offline   Reply With Quote
Old 03-13-2013, 09:29 PM   #9
70cst
70cst's Avatar
Hey Chelmore ...
First of all... to the forums and from Ohio.
on one ride. 69 and 70 model trucks are specil. Than again I am bias
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 03-14-2013, 06:13 AM   #10
daves72C10D
daves72C10D's Avatar
Welcome. 74k miles is just broke in.
1972 Custom 10 Deluxe- original paint, interior- 72k miles
http://www.cardomain.com/ride/2466316
Cheap, Fast or Good. Pick any two.
1990 Eagle Talon AWD
1991.5 W250 CTD
1992 Cushman Truckster- Haulster
daves72C10D is offline   Reply With Quote
Old 03-14-2013, 04:47 PM   #11
MidLifer
MidLifer's Avatar
got pics? 69 barn find with 74k must look sweet
MidLifer is offline   Reply With Quote
Old 03-14-2013, 05:26 PM   #12
JOJABOY
Are you sure you have an electric choke? I had similar issues with mine when I first bought it. I installed a choke thermostat and now it starts with two pumps every time. Even early in the morning when it's cold and has been sitting.
JOJABOY is offline   Reply With Quote
Old 03-14-2013, 11:11 PM   #13
70blackfish
Pictures????????
69 SWB 780hp Hellcat powered, manual 6 speed, currie 9
70blackfish is offline   Reply With Quote
Old 03-15-2013, 11:29 AM   #14
srvivor71
srvivor71's Avatar
Welcome form NY! Let's see some pics of that ride!
srvivor71 is offline   Reply With Quote
