Old 03-13-2013, 08:42 PM   #1
tabarcus
72ChevyStep
Automatic Brake Pedal Assembly
Automatic Brake Pedal Assembly removed from a 1971 C-10. $45 shipped.
tabarcus is offline   Reply With Quote
Old 03-13-2013, 08:48 PM   #2
brewtality
brewtality's Avatar
Re: Automatic Brake Pedal Assembly
I have a 67 that is currently a standard. I am doing an auto swap. Any idea if this will work?
brewtality is offline   Reply With Quote
Old 03-13-2013, 08:52 PM   #3
29od1
This is what you need as far as the pedal assembly goes.
29od1 is offline   Reply With Quote
Old 03-13-2013, 08:59 PM   #4
tabarcus
72ChevyStep
It should work, as long as the mounting holes in the 67 Cab firewall aligns with the master power booster in the engine compartment. BTW: The Power Brake Boosters are made for 67-72's so my quess is yes, it will work.
Old 03-13-2013, 09:03 PM   #5
HotRod C/10
HotRod C/10's Avatar
I just unbolted the clutch pedal. This is more for those that are totally missing a pedal.
SOLD -77 CHEYENNE SWB,
LS SWAPPED
-1976 SILVERADO
YUBA GOLD/NEUTRAL (2-TONE)
HotRod C/10 is offline   Reply With Quote
Old 03-13-2013, 09:10 PM   #6
jeh
jeh's Avatar
Has the arm been cut and welded?
Jason
'70 C-10 short fleet 427BB TH400 (SOLD)
'10 Ford F 350
'13 Ford RAPTOR 6.2
MY BUILD THREAD http://www.67-72chevytrucks.com/vboa...d.php?t=612623
jeh is offline   Reply With Quote
Old 03-14-2013, 11:55 AM   #7
tabarcus
72ChevyStep
Yes, the assembly is modified. Sure makes it easier for your foot to find the brake pedal, so if you have long legs, its the perfect setup and its not that noticeable when installed. If interested, let me know.
Old 08-25-2014, 08:54 PM   #8
tabarcus
72ChevyStep
ttt
Old 08-25-2014, 09:55 PM   #9
EdSevered
EdSevered's Avatar
I also have a '71 that I am upgrading to power brakes from manual. Will I need to replace the current pedal assembly with one like this unit?
Thanks! -Ed
EdSevered is offline   Reply With Quote
Old 08-26-2014, 02:06 PM   #10
tabarcus
72ChevyStep
Yes
Originally Posted by edsevered View Post
i also have a '71 that i am upgrading to power brakes from manual. Will i need to replace the current pedal assembly with one like this unit?
Thanks! -ed
Old 10-15-2015, 03:48 PM   #11
downbytheriver
downbytheriver's Avatar
Long time ago, but has this sold?
68 SWB 5.3 turbo build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=578220
downbytheriver is offline   Reply With Quote
