03-14-2013, 10:37 AM | #1 |
C-20 & C-10 Frames???
I have a 69 C-20, now does anyone know if the Frames are the same as the C-10 Frames and just the Suspension is different, or are they completely different Frames?
Thanks! |
03-14-2013, 01:25 PM | #2 |
Junior Member
Re: C-20 & C-10 Frames???
They are basically the same if you are talking about ones with trailing arms. I think that the 3/4 ton frames are a little heavier gauge, have extra bracing at the trailing arm cross member and the trailing arms have plates welded on them.
Also the rear cab mounts are lower on the frame to allow thicker rear cab mounts to give a smoother ride in the cab.
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
03-14-2013, 01:51 PM | #3 |
C Blazer
C10 115 C10 127 6.04" height 2.53" flange width 0.156" thick 2.98 section modulus C20 127 6.11" height 2.46" flange width 0.194" thick 3.71 section modulus
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
03-14-2013, 05:46 PM | #4 |
03-14-2013, 07:41 PM | #5 |
To what end are you building?
03-14-2013, 09:18 PM | #6 |
A body dropped truck that lays frame/body on air suspension, with all new dropmember, just didnt know if the frames were the same in all aspects or not
Posted via Mobile Device |
03-14-2013, 09:27 PM | #7 |
Understand, that is a direction I can't help you with. But if I were cutting down a frame a C20 frame is going to be a lot stiffer (~23%) and would seem better able to withstand local loads it was never designed for.
03-14-2013, 09:29 PM | #8 |
Yes plan on cutting it down and doing a shortbed, is the frame tallee?
03-14-2013, 11:05 PM | #9 |
Taller I meant?
03-14-2013, 11:12 PM | #10 |
The GM published numbers are up above. Yes the frame is a little taller, about 0.070". The big improvement is that it is just over 25% thicker 0.194" vs 0.156".
03-15-2013, 12:00 AM | #11 |
Thanks for the info
