03-14-2013, 11:47 PM | #1 |
Dually Rear End Question
After working on my brakes today, I seen something for the first time. It's and 86 C30 Crew Cab. There is a bar that is mounted to the rear axle towards the passenger side that extends up to the frame. The mount on the frame swivels, I'm assuming when the axle goes up and down. I know it has the sway bar, but does anyone know what this other thing is?
Thanks |
03-15-2013, 01:33 AM | #2 |
Re: Dually Rear End Question
Got any pictures? Does it have brake lines running in and out of it? If so, that is the rear proportioning valve. It gives you more rear brake bias as weight is put in the bed or on the bumper.
03-15-2013, 09:28 PM | #3 |
Looks like at one time it had lines ran to it. Is it worth putting it back in working condition?
03-15-2013, 09:32 PM | #4 |
It might be. The biggest question there is, why was it unplumbed? Unfortunately, hooking it up is the only way to find out. I don't know of anyone that sells them, but maybe someone else will jump in and help me out with that. If you are going to haul or tow a lot, it would be worth giving it a shot. If you are just driving it with the occasional load, might not be worth it.
Posted via Mobile Device |
03-16-2013, 03:31 PM | #5 | |
It sounds like the height sensing proportioning valve. It was put there as "test beater" to pass the stopping distance portion of the federally mandated MVSS105 and MVSS208 brake tests. At curb, when there is less weight, the rear end sticks up and the brake line pressure is limited to the rear brakes, preventing lockup and skidding. When weight is added, the rear end goes down, tripping the valve open and allowing full pressure to the rear brakes (and additional stopping power). It's how we did it in the days before ABS braking. You would probably be fine without it. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
03-16-2013, 04:51 PM | #6 |
mine has one on it (not like im contributing, just sayin)
"DON'T TOUCH THE TRIM!!"-Early Kyler |
03-16-2013, 05:15 PM | #7 |
I think im going to ditch mine when i swap the axle....
88 3+3 454 400 205 410 drw to srw still in pieces 90 3+3 350 400 205 410 srw 84 1/2 ton lb 6.2 4x4 parts truck |
03-16-2013, 11:21 PM | #8 |
Hey I appreciate all the comments and information from all of you. I ended up leaving it unhooked, a new one was around $400 and I don't think I'd benefit from it anyways.
03-17-2013, 12:46 AM | #9 |
At the body shop.
Did a 1/2 axle swap under a R3500 and bypassed the valve. Truck drives stops great.
" That didnt make it any newer " " Dont antique the equipment " |
03-17-2013, 01:12 AM | #10 |
I have a K30 CC, had a 14 bolt and swap a dana 70, took it off and threw it away. It works great without it.
