another bumper question..88 burb bumper on 74 truck
I got my sport bumper on yesterday but it don't look right. im only using the outer brackets since the inners don't work. the bumper looks turned down a bit...how can I get the bumper up straight ? is the burb outer brackets different from the trucks?
Re: another bumper question..88 burb bumper on 74 truck
some trucks even new had bumpers that pointed down a bit. on one truck i just unbolted the bumper brackets & went at the holes with a dremel. opened them up enough so i could twist the bumper up level.
You need the right brackets and the filler panel. Personally I think those stick out way too far so I would just modify/build your own.
Next!
Here's how the bumper looks with the right bracketes
86 K30 CUCV M1028A1 86 K30 CUCV M1028a2 dually 86 K30 C&C 6.2 4:56s, 4M, 11,000 gvw, ex fire truck, now lowboy dump More square bodies and CUCVs than I care to admit to 2020 Silverado K3500HD Work truck |
I have little to no fab skills or tools so makin new brackets is out. Do I just get 81-87 truck brackets?
Posted via Mobile Device |
Ask a muffler shop or a welding shop. They'll will probably do it cheap enough to forget scrounging one up.
maybe I might just drill new holes or do what dieseldawg did and widen the existing holes with a dremel
heres the brackets...they look like they're on right...let me know if its not...these are the best pics I can get right now..i know there crappy...its freezing out
it is a little hard to tell, but your bumper does seem to point down. i have a sport bumper on my crew, here's what the brackets look like mounted. in one of your pic's it looks like the bolts are in line, they should use the holes so the bolts are off-set, the top bolt more to the front of truck, that should pull your brackets up some
#10 | |
#11 | |
those are the only holes...I took it to my mechanic's shop and we had on a lift...I checked to see where the holes were and those were the only ones I seen. I checked again when I was takin these pics. seems like we think alike...that's exactly what I'm gonna do...i'll see If I could borrow someones cord drill if my cordless don't work on it.
bummer! guess your drillin'. was'nt going to say anything, but about 25 yrs ago all i had was a 9.6 makita cordless (the big one back then!), and i really needed some tow hooks on the back of my jimmy. between cool-downs & recharges i think i spent 2 or 3 hours. at least you only need 2 holes
The 81-87 bumpers and brackets are different from the 73-80. That's why you are having the problems. I'm curious how it ends up looking after you drill holes to level it out.
#15 |
i'll be sure to post pics when I get it done...the weather in south Dakota sucks a**!!..hopefully I get it done soon..its buggin the heck outta me.
#16 |
got it done...just widened the top holes and that was that..easier than I thought...glad I didn't have to drill more holes on my frame.
#17 |
That looks great! The 73-80 bumpers are harder to come by and I can get 80's suburban bumpers much easier. Thanks for the pics!
#18 |
nice job ivorton, looks good
#19 |
Thanks fellas!
