03-17-2013, 09:12 PM | #1 |
Need Help slammin a 61 Apache!!
Hey guys im a newb on this site just looking for suggestions
on slammin my 61. Here's what i had in mind. urning torsion bars all the way down 2.5 drop spindles Disc brake conversion 5 lug conversion 4" drop spring in back 20x10 in back with 295 tires 20x8.5 in front with 255 tires. What are your thoughts? Thanks in advance!! Posted via Mobile Device Last edited by mikes61; 03-17-2013 at 09:31 PM. Reason: pictures |
03-18-2013, 11:47 AM | #2 |
Re: Need Help slammin a 61 Apache!!
Any help would be appreciated.
03-18-2013, 01:34 PM | #3 |
Not a great pic but heres my 60 2 1/2 dropped spindles disc brake convertion with 4" drop coils in the rear. I also turned the torsion bars and lowered it maybe 3" more. Bottom of the bolts on the torsion bar is about 4" from the ground... running 7" smoothies 6 lug. you might have a rubbing problem with the 10" need to check..
CURRENT & PAST CHEVY TRUCKS 60 C-10 Apache short step side 62 C-10 short step side 66 GMC Long bed fleet side 305 V-6 77 C-20 Custom Deluxe (Blue Goose) |
03-18-2013, 01:56 PM | #4 | |
03-18-2013, 02:45 PM | #5 |
Got all my stuff from CPP 5 years ago and very happy with thier products... I also installed a dual master cylinder and brake booster..heres another pic..
03-22-2013, 11:45 AM | #6 | |
03-22-2013, 03:00 PM | #7 |
No they are 7" smoothies from (Wheel Vintiques)... and you are correct - stock wheels will not clear the calipers...
03-18-2013, 02:28 PM | #8 |
Thanks for the imput! Do you have any issues with the 4" drop coils in the rear. I dont really want to c notch.
03-18-2013, 02:52 PM | #9 |
Nope not at all... I can probably still install 2" blocks at the rear but not gonna do it.. heres a rear view pic..
03-18-2013, 04:43 PM | #10 |
I had 2.5 inch drop spindles and the torsion bars lowered 2 inches and that worked fine. the nice thing about torsion bars is you can always go back up. make sure you count how many times you turn the bolts and remember it takes a little driving to get them to settle. A 5.5 inch drop in the front and 4 in the back will give you one heck of a rake. I think you can go as low a 5.5 in the back without notching the frame but you will need to get rid of the bump stops.
03-18-2013, 04:52 PM | #11 |
One with out hood.
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
03-18-2013, 04:50 PM | #12 |
Going with Porterbuilt front, but took the bump stops out up front. The rear has bags and won't go lower with out two piece driveshaft, bumpstops keep the shaft from hitting. No spindles yet but when time comes it will. Look at projects and builds for pictures and my cardomain page as well.
03-19-2013, 03:44 PM | #13 |
I too bought the 2.5 inch dropped spindles and 6 lug disc brake from CPP and kept my torsion bars. Rode it for a while with rear coils that I lowered with torch but later sprung for the 4 in drops and improved the ride. Threw on a dual diaphram master/booster also and sway bar. Good thing about the torsion bars is you can lower or raise the front with ease for a wicked rake. Been running this set up since '01. I started to swap the front suspension for coil springs but I think im gonna hold on to what I have. I plan on bags as well but don't intend to slam it to the pavement. Been pleased so far but want a more of a 'cadillac' comfort ride in the near future..
03-21-2013, 09:24 AM | #14 |
Where did you get the dual diaphram master?
03-21-2013, 03:52 PM | #15 |
..I meant dual master cylinder and a dual diaphragm booster.
Sorry, thought it was implied. Posted via Mobile Device |
03-22-2013, 09:27 AM | #16 |
Verdell is your truck a auto or manual ?
03-22-2013, 04:45 PM | #17 |
03-22-2013, 05:37 PM | #18 |
Thanks !
