Cutting springs
I purchased 1" front lowering springs from ECE and now want to drop another inch. Can I just cut them or would it be better to purchase new ones? Thanks
Posted via Mobile Device |
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: Cutting springs
Cut 1/2 coil for a 1" drop.
Re: Cutting springs
My research on here tells me yes you can cut front but best to go 1/2 coil at a time because once you go to far you cant go back. The rear cant be cut if you were wondering.
Re: Cutting springs
If I cut half a coil will it still sit in the pocket correctly?
Re: Cutting springs
Re: Cutting springs
Ok perfect. Thanks for the quick response.
![]() Join Date: Mar 2012
Re: Cutting springs
Its actually the bottom that needs to sit correctly into the lower control arm. The top doesnt matter. If you get the spring out of place on the bottom, it can make up to an inch difference in height and make the truck sit crooked.
#teamlongbed "I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb 1978 Chevy shop truck - static 6/8" 1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497 |
#8 | |
Re: Cutting springs
![]() Join Date: Jan 2011
Re: Cutting springs
I can't express enough, go a little at a time. I cut one full coil off a CPP spring expecting about 2" drop and it was more like 2.5+"
I think the spring not only loses overall length but also if you think about that loss of spring tension will also cause it to drop. It's a little deceiving. Ex: Cut one full coil off, and stand on it (the part you cut off) Can you compress that 'one round' of the original coil? You not only lost the length of the spring, but the weight it once held up.. .. just kinda how it was explained to me. My .02 Chad
Re: Cutting springs
if u cut too much they are quite dificult to glue back together
Re: Cutting springs
3M is making a great epoxy that you might try
72 Chevy LB, LS in the works, 4L80, Grandfather bought it brand new. 66 GMC Short Step, 84 Front Suspension, many more mods to come 67 Chevy 3/4 Ton, 327, Auto, Factory A/C Ya must have been movin cause I was haulin a*$ when I passed you |
#12 | |
the boat guy
Re: Cutting springs
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
Re: Cutting springs
This is correct. A spring is the same as a lever, except in the form of a coil. The shorter you cut it, the rougher the vehicle will ride because you increase the spring rate. On the old dirtbikes, we used to stiffen the front forks by cutting an inch off the coil springs inside the fork tubes and installing a 1" spacer. That way you have the same ride height, but a stiffer spring. You can google it if you want. Its physics and engineering.
Re: Cutting springs
Cut 2 in off the length, why would it drop more than 2" ? Not arguing.. just asking. If it got stiffer would it only drop say.. 1.5" ?
#15 |
Re: Cutting springs
I stand corrected. So why does cutting 2" of spring length off, drop the truck more than 2" ?? Just curious.
