03-18-2013, 12:52 AM | #1 |
10 000 lb Superwinch
local parts store has Superwinch winches on sale. 10000 lb for $399, 15500 lb for $899. i would rather have the 15500 (1 ton crew), but for $399 & double lining, how good are they, seems like a big price drop between the 2, any body using either of them?
03-19-2013, 02:29 PM | #2 |
Re: 10 000 lb Superwinch
They're good winches from what I've heard. My best friend has one,not sure which,but at least 12k if not the 15. He's not afraid to use it and it's been doing everything it's been asked to do. $900 is great for a 15,000# winch. $400 for a 10k??? That's crazy cheap. But,it's just not quite enough for a full-size truck. I'd want at least 12,000#. Not saying a 10k would be worthless,but I'd want more
03-19-2013, 08:24 PM | #3 |
Superwinch has a couple of lines, just make sure it's their premium winch and you'll be good to go. I had an S2500 on my car trailer for a long time, just recently replaced it with an S5000. Not because the 2500 had failed but because the bigger winch has a wired remote. And it's faster. Been very happy with Superwinch.
With that said, I have a Warn 9500 on my Duramax truck. It is a short drum winch that mounts between the frame rails. Only has 50 feet of cable, but I've drug my truck with car trailer behind it and a K2500 Suburban on it out of the mud. Not buried to the frame rails, but unable to move forward on its own. 10,000 pounds should be plenty of winch for occasional recovery.
03-19-2013, 10:18 PM | #4 |
Most non indusrial electric winches are rated at stall, that is the point that the electric motor can not move and the input current is at maximum. Also, if your electrical system can not supply that current level the winch will stall at a lesser load level. Usually most winch manafactures will create a higher capacity winch by increasing the gear ratio and in turn slowing down the line speed. It will pull more but it will require a longer time to pull the load. Check all the manafactures specs. Quality winches are SAE 706 rated. They are rated to actually run and pull at the max rated amount. They also have a bult is safety factor.
1988 V30/6.2/Sm465/NP205/5x6 4.56 axle/12,000 lb.GVW/Ramsey L600 front winch,Chelsea 321PTO on trans/ Ramsey L800 rear winch,Chelsea 352PTO on transfer/ custom steel flat bed with rear rollers. |
03-19-2013, 10:33 PM | #5 |
The 10,000 lb which would probably be enough for most 3/4-1ton apps. Unless your in mud above the frame,should be ok.It's not like your trying to lift the truck straight up.Another option is using a snatch block & doubling your pulling power.
1977 Chev C30 454/465/14ff DRW 1974 Chev C20.350/465/14ff " Rock n Roll ain't noise pollution" |
03-20-2013, 12:39 AM | #6 |
thanks for the replies. i had to do a double take when i saw $399. the last winch i had was a Milemarker 12500, good winch. my dad's running a Warn 8274 (since '84 or'85!). i would rather get a 15k winch (my crew is right 7500lbs), but for the price, i'm going back there tomorrow & buy one. now that i have receivers at both ends, i will be cradle mounting it, & if turns out not strong enough, i can always put it on my stepside & upgrade the crew
03-21-2013, 04:45 PM | #7 |
Another Day, Another Dollar
Princess auto?
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box "its hip to be square" |
03-21-2013, 11:37 PM | #8 |
^^^yup
03-22-2013, 12:12 AM | #9 |
Now the light bulb goes on!! I saw those winches in p/a last week in RedDeer.
03-22-2013, 04:41 PM | #10 |
A couple of my buddies bought them. I have heard they're comparable to a warn 6000 lb internally and the thing that I find sort of unnerving about them is that they are made to mount bottom down as opposed to the front bolting into your bumper. All of the pulling fore will be yanking on the bolts instead of pressing against the bumper. One of my buddies clocked his though so it does press on the bumper.
Does this make sense? Posted via Mobile Device
03-22-2013, 07:54 PM | #11 |
well, went & had a good look at the 10k, i just dont think it's going to cut it on my crew. but i bought one anyways, (to cheap not too) it will find a nice home on my s.side. i still got 2 yank straps & a 75ft KERR rope for the crew 'till i find what i really want- a warn 16.5 or milemarker 15.5
03-22-2013, 10:16 PM | #12 |
That extra $500 price difference will buy a lot of cable and snatch blocks. I like good equipment, but I would take a $400 10k winch and $200 worth of accessories over a $900 15k winch any day. Heck, with enough additional equipment, I can pull a Semi out of 6 ft of mud with a 2000lb winch.
I know a little about cars, but if you have a question about electricity or sport quads, I'm your man!!! |
03-23-2013, 12:08 AM | #13 | |
03-23-2013, 03:27 PM | #14 |
Location: On the banks of the Clackamas River, Eagle CreeK Oregon
Superwinch has been manufcating that sidewinder design since the early-to-mid 70’s. Vic Hickey may have been first with it, I am not sure… I do recall that Vic advertised his winches by hanging a K5 blazer from an Oak tree limb…
I have one on my 79’ K-30, PO says was factory installed ( I doubt it, more than likely dealer installed) but Hey’ it still works… |
03-24-2013, 04:31 AM | #15 |
seen something similar to that. was going by the car wash once, & a guy with a jeep had thrown his winch cable over a steel beam holding up the roof & winched it to about a 50-60 degree angle & was spraying mud off the bottom
