Old 03-18-2013, 05:48 PM   #1
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
pics of door seals
odd request i know but i would like to see pics of ppl's door seals. perf crew/burban front/rear
If it aint square, I don't care.
84 C35 CC Dually Project log...
http://67-72chevytrucks.com/vboard/s...d.php?t=414892
1tonchevy is offline   Reply With Quote
Old 03-19-2013, 07:40 AM   #2
riz
Re: pics of door seals
Here's mine in progress. Still left long on the bottom until they relax and stretch a bit before cutting to fit.
RIZ
riz is offline   Reply With Quote
Old 03-19-2013, 08:45 AM   #3
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
RIZ
is there a seal on the door it's self or just the cab?
Old 03-19-2013, 09:39 AM   #4
riz
Just on the cab.
RIZ
Old 03-19-2013, 10:50 AM   #5
dieseldawg142
dieseldawg142's Avatar
just changed the rear door on my '85 crew with a '77 sub door. older doors also had a piece of weatherstrip on the top half of door. i ditched it & used the one on the cab
dieseldawg142 is offline   Reply With Quote
Old 03-19-2013, 02:37 PM   #6
motornut
78K & 79C Jimmys
motornut's Avatar
I think the 78 had them till body work(dirty mark) but the 79 still does
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 03-19-2013, 03:07 PM   #7
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
none of my doors have the "door seal" do they add any noise reduction/keeping weather out?
Old 03-19-2013, 03:30 PM   #8
motornut
78K & 79C Jimmys
motornut's Avatar
I think so,
but my 78 is 4X4 with leaky,and sometimes moving ,outer seals, no inside panels,in the rear ,roof liner etc
the 79 is 4X2 is quieter to start with the rear panels , roof liner etc
I'd say yes,it seems like the inner seal, makes less noise come in
and even a softer closeing thud
John
Old 03-19-2013, 10:58 AM   #9
Precision Parts
Tech Help
Precision Parts's Avatar
Just a reminder for those who may not know. When trimming the excess, never cut in line with other end, always overlap about an inch then butt the two ends together and press the excess backwards through the seal. Not only does this help compensate for shrinkage but also creates pressure at the ends for a tighter bond.
PRECISION
Updates
Subscribe --->Installation Videos
Follow ------->Instagram
Like---------->Facebook
Precision Parts is offline   Reply With Quote
Old 03-19-2013, 12:03 PM   #10
riz
Exactly. You can see the bad job the previous owner of mine did on the post above. There was a good couple inches of gap on the bottom. MY new seals will be tight.
RIZ
Old 03-19-2013, 11:13 AM   #11
trout
up intail 82 i believe they put seals on the top of the doors from the factory
Edited by staff
trout is offline   Reply With Quote
Old 03-19-2013, 12:22 PM   #12
Precision Parts
Tech Help
The rear Suburban door seals take the same extrusion as the fronts, they are installed in the same way.
Did you have a more specific question?
PRECISION
Updates
Old 03-19-2013, 12:25 PM   #13
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
wondering if all trucks came with both seals (on cab/on door)
Old 03-19-2013, 01:04 PM   #14
Precision Parts
Tech Help
All pickups/Suburbans 73-87 (91) had the same on-body press on bulb seal for the front & rear doors. You need to trim more from the rear doors since the opening is a little smaller.
The upper door seal is a little strange. As trout mentioned correctly earlier the front door upper goes 73-82. The rear door (according to the GM books) goes up to 91. This, like I said seams a little strange to have an upper on the rear but not the front from 83-91, but that's what our research showed when we tooled these parts.
Derek
PRECISION
Updates
