Old 03-22-2013, 05:57 PM   #1
cool1972gmc truck
need new radiator
i need a new radiator for my 1972 gmc truck, has anyone heard about a spectra premium radiator? i can get one new for less than 200.00 dollars plus a lifetime warranty at my local auto zone. any ideas or suggestions???
cool1972gmc truck is offline   Reply With Quote
Old 03-22-2013, 06:07 PM   #2
joesgreen67
joesgreen67's Avatar
Re: need new radiator
Im running a champion alum radiator I got for less than $200 from ebay....im happy with it
joesgreen67 is offline   Reply With Quote
Old 03-22-2013, 06:09 PM   #3
Mister-B
I'm guessing it is one of those lighter aluminum ones? If you've go the original radiator in your truck, why not just have it repaired? Will probably run you about $90 if you remove it yourself, and you'll still have your heavy duty radiator
Mister-B is offline   Reply With Quote
Old 03-22-2013, 07:18 PM   #4
calvin78612
calvin78612's Avatar
I have a champion also,and am very happy with it.
84 step side
87 swb
calvin78612 is offline   Reply With Quote
Old 03-22-2013, 07:23 PM   #5
Lee H
Lee H's Avatar
I have no problems with buying a radiator from a local DIY store that has a lifetime warranty. That way if there is ever a problem you can return it and your going again the same day. With any luck it will be a copper/brass and look just like to stock one.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 03-22-2013, 09:24 PM   #6
Daddy Brim
Daddy Brim's Avatar
I got mine from O'Reilly. I'm pretty sure it is from Spectra, I got the 4 core. All metal tanks, and you can not go wrong with a lifetime warranty.
I'm sorry I called you stupid. I thought you knew already.
67 C-20 Custom Camper
68 Nova 396 it does wheelies
2005 Buick Century the one the wife drives
1989 Toyota Tercel to drive when I can't put gas in the first 2.
Daddy Brim is offline   Reply With Quote
Old 03-22-2013, 09:55 PM   #7
ole dollor
ole dollor's Avatar
i also got mine from e-bay , champion alum. good so far.
ole dollor is offline   Reply With Quote
Old 03-23-2013, 04:00 PM   #8
PatrickGMC70
PatrickGMC70's Avatar
I just got my original radiator cleaned, pressure tested, and had a leak repaired for $80 this week. Only took them a day to get it back to me. Could be an option for you, though radiator repair shops are getting harder to find.
PatrickGMC70 is offline   Reply With Quote
Old 03-23-2013, 04:36 PM   #9
Gumby
Gumby's Avatar
stick with copper, it works better, yes its bigger but copper disapates heat better. Its only bigger because of the limiting factor of the wall thickness of copper.
Good copper 4 core from any auto parts store
plus were talking trucks with room, not a FWD rice burner that has no other option but to use aluminum. big 3 switch to it was only for space and money savings, not because it was the best.
Gumby is offline   Reply With Quote
Old 03-23-2013, 06:05 PM   #10
eagleuh1
eagleuh1's Avatar
I replaced mine in my 68 C20 with a Spectra Premium from AutoZone in Pheonix Az. Almost exact duplicate of the original 4 core radiator that was in it. If I'd had the original fan shroud it would have worked perfect. I had to redrill some holes to mount my aluminum electric fan shroud to mount them. Otherwise very happy with the quality and fit of the radiator. Recommended.
eagleuh1 is offline   Reply With Quote
