Old 03-23-2013, 02:27 PM   #1
kikkegek
kikkegek's Avatar
Grease upper balljoint on 4x4
guys I need some help please.
I have tried every thinkable position of te wheel and axle, but cant reach this grease fitting.
I have tried regular connection and needle...
how do you guys grease these babys?
kikkegek is offline   Reply With Quote
Old 03-23-2013, 04:22 PM   #2
Pano
Re: Grease upper balljoint on 4x4
I am not sure what you've got but check out this website, it says factory ball joints don't have grease fittings.
http://www.chuckschevytruckpages.com/lubepoints.html
Pano is offline   Reply With Quote
Old 03-24-2013, 12:23 AM   #3
hatzie
Moderator
hatzie's Avatar
The installer should've used a 90° Zerk.
The only thing I can think of in your situation is a low profile slotted 90° grease gun fitting like this one http://www.amazon.com/Lincoln-Lubrication-5883-Slo... http://www.amazon.com/Lincoln-Lubrication-5883-Slo......
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 03-24-2013, 06:15 AM   #4
kikkegek
kikkegek's Avatar
The only thing I can think of in your situation is a low profile slotted 90° grease gun fitting like this one http://www.amazon.com/Lincoln-Lubric...gy_auto_text_y...
I went out to buy such a fitting, but the guys behind the counter at the tool shop told me those are for these flat grease fittings:
that is why he sold me a neeld adapter:
but so far I have moved the car a hundred times, but not been able to get the right angle to grease the fittings...
hope somebody can shine some light on this based on personal experience...
Old 03-24-2013, 12:25 AM   #5
Walts_restoration
Real Projects never die
Walts_restoration's Avatar
That was a master pro joint. Lol moogs offset so that you can grease them with axle in place.
Ill put it this way, ive got a few lawn ornaments
My name tag says Ryan
KansasTwister On other forums
Walts_restoration is offline   Reply With Quote
Old 03-24-2013, 02:11 AM   #6
dieseldawg142
dieseldawg142's Avatar
could you get something like this in there?
dieseldawg142 is offline   Reply With Quote
Old 03-25-2013, 02:46 AM   #7
cory d
cory d's Avatar
another reason to not buy master pro
cory d is offline   Reply With Quote
Old 03-24-2013, 07:58 AM   #8
Zane M
You should be able to remove that zerk and install a 90 degree one in its place. Then, as long as you have it positioned correctly, you will be able to get a grease gun onto it.
Zane M is offline   Reply With Quote
Old 03-24-2013, 11:02 AM   #9
bilfman
bilfman's Avatar
Originally Posted by zane m View Post
you should be able to remove that zerk and install a 90 degree one in its place. Then, as long as you have it positioned correctly, you will be able to get a grease gun onto it.
x2
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205
1971 GMC 3/4 Ton 4X4
bilfman is offline   Reply With Quote
Old 03-24-2013, 11:18 AM   #10
kikkegek
kikkegek's Avatar
Guys,
got any pictures of these 90 degree angle zerk fittings in place? I am asking this, because in my case it seems there would just not be nough room in there for such a fitting.
Old 03-24-2013, 01:41 PM   #11
LONGHAIR
Originally Posted by kikkegek View Post
Guys,
I'm pretty sure you can't. The way I remember them back in the day was with a plug. You would install the knuckle, after pressing the ball-joints into it. Screw in the regular straight fitting, grease the joint as usual. Then you remove the fitting and install the plug that came with it. They were shorter than the fitting and less likely to break.
Apparently the thinking was that you would need to service the axle joints again by the time you needed to add grease to the ball-joints?
Before Spicer came up with the geaseable axle joints, they were un-serviceable too.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 03-24-2013, 05:29 PM   #12
motornut
78K & 79C Jimmys
motornut's Avatar
thats what i was told doing mine in the 87
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 03-24-2013, 05:52 PM   #13
hatzie
Moderator
hatzie's Avatar
Try one of these with the U-Joint turned to the right position...
Old 03-24-2013, 06:12 PM   #14
LONGHAIR
Those require a specific fitting, not the typical zerk.
Old 03-24-2013, 11:37 PM   #15
hatzie
Moderator
hatzie's Avatar
I've used one on straight zerks that were difficult to reach at best. Dirty grease squirted out around the unsealed shaft away from the zerk so it was feeding through and not just making a mess at the zerk. It wasn't a super tight seal though.
I'd be interested to see the fitting they were actually made for. If it's low enough profile it might be worth changing to... in places like the upper Ball Joint on the Dana44 and down those nasty holes on the baler and the chopper... If I can reach em to swap em out.
Old 03-25-2013, 01:25 AM   #16
kikkegek
kikkegek's Avatar
I posted it in one of my previous posts:
Old 04-20-2013, 10:00 AM   #17
kikkegek
kikkegek's Avatar
okay, today I tried this fitting. got it from Amazon for great deal.
I thin I had it hooked up, but still no grease went into the zerk fitting I think.
man, this greae point is giving me a head-ache.
any 4x4 brothers here that succeeded?
Old 04-20-2013, 01:04 PM   #18
kikkegek
kikkegek's Avatar
anybody know the thread of these fittings?
I want to remove the straight fitting and use a 90 degree fitting to grease it and when I am done plug it with a blind fitting.
what is the thread size?
what are the blind fittings called? any special name?
Old 09-17-2013, 10:12 AM   #19
kikkegek
kikkegek's Avatar
guys!
suc6!
so happy.....tried the Thexton grease coupler again today and I guess I never had it put on correctly before.
I used a plier to put it on and then connected the grease gun...et voila! suc6...upper balljoints are greased now.
just wanted to give heads up over here on my succes.
this is the link to the tool:
Thexton THE418 Grease Coupler
Thexton THE418 Grease Coupler : Amazon.com :... Thexton THE418 Grease Coupler : Amazon.com :...
