Old 03-23-2013, 10:08 PM   #1
nosfed2
9.5 MPG!!!! Please Help!!!!
Ok so it is a 1984 Gmc 1500 2wd It has a New 350ci with 1200 miles on it with a RV cam. It also has a 700R4 tranny with 2.73 gears in the rear.It has a stock intake and Quadra jet on it that has been rebuilt by national Carbs, It does not smoke or smell like its running rich. I pulled the plugs and they are perfect. I dont care about towing or anything, we drive it to swap meets that are 30 to 70 miles away one way. We need it to get the best gas mileage possible. The thing is that I watch the tech and at 55mph it is at 1500rpm it never gets over 2000rpm even on a hill so I dont understand how it can be getting such bad mileage. We checked the brakes and wheel bearings for drag but they are all ok. It also has 31X10.50 wheels on it.What is the Deal?
nosfed2 is offline   Reply With Quote
Old 03-23-2013, 11:14 PM   #2
muddnutz
muddnutz's Avatar
Re: 9.5 MPG!!!! Please Help!!!!
hard to get good gas mileage driving a brick im getting 10 mpg out of mine with a 4" lift and 35's stock gm350 put in 2 years ago with a 700 r4 how many miles are om your stock cats?
1986 K-10 "ole blue"
muddnutz is offline   Reply With Quote
Old 03-23-2013, 11:25 PM   #3
INSIDIOUS '86
INSIDIOUS '86's Avatar
With those 273s good luck. Change to 308s and it should go up actually.
I'm guessing the stock intake and manifolds and qjet are just having a field day killing your efficiancy
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 03-23-2013, 11:35 PM   #4
Desert1957
Desert1957's Avatar
Very true, I went from 2:73 to 3:42 in this 87 and mileage went up 3 MPG.
It also has 31 X 10.50 tires.
Desert
Desert1957 is offline   Reply With Quote
Old 03-24-2013, 03:58 AM   #5
85sierraclassic
85sierraclassic's Avatar
Try running it in drive and not overdrive and see if it improves lower rpms don't always make it more efficient.
85 GMC sierra classic : 350, 4spd, 205, 3.42s, 35s
85sierraclassic is offline   Reply With Quote
Old 03-24-2013, 04:20 AM   #6
cleansquare
Yes you have issues. I am getting 12.2 in my 3/4 ton 85 with 350 and 3 speed trans. Course I have 4.10s headers no cats aluminum intake flat top pistons etc. Runnibg 3300 rpm at 70. Still sucks tho which is why im swapping in the 4L80e now
cleansquare is offline   Reply With Quote
Old 03-24-2013, 04:39 AM   #7
dieseldawg142
dieseldawg142's Avatar
welcome to the club!, 6 mpg's, 7 when i can pick up the jet stream
dieseldawg142 is offline   Reply With Quote
Old 03-24-2013, 07:41 AM   #8
tucsonjwt
I would have thought that a lower rear axle ratio would provide better gas mileage. City mpg has always been 9-11 best on any of my 3 squares - 73 454, 76 350, 83 454. I rarely drive highway but the 83 got 13 mpg best on the highway with 4.10 rear axle.
I bought an old beater Cavalier for most of my driving (24-26 mpg), and rent an economy car when I have to drive a long distance out of town (usually costs less than $20/day.) You could also rent a V6 pickup from Uhaul when you need one (or Enterprise), but it would cost $20 to start with, then a mileage fee, but probably still less than owning a truck if you don't rent one very often, considering the savings on fuel, insurance, registration, etc.
My best pickup mileage was 19-20 city/22-24 highway on a 2000 Silverado V6 with 3.42. You might consider looking for one of those, since you don't want to tow with it. Another option might be a late model Tahoe with 4.8 and 3.42 for better gas mileage and still lots of cargo space, plus a very comfortable ride. I have owned several Tahoes/Yukons purchased new in the past 10 years and the worst I got with any of them was 17 mpg city - but I do drive like the senior citizen that I am
tucsonjwt is offline   Reply With Quote
Old 03-24-2013, 08:39 AM   #9
SSC's76
No No
SSC's76's Avatar
What was posted above is correct to low rpm will kill fuel economy just to same as spinning it to fast granted not as bad. You want your highway rpm to be inline with the power range your camshaft makes the most torque. 500 plus or minus so if your cam specs say peak torque at 2500 you want to be 2-3000 rpm on the highway to see the best results usually the lower limit is better. If you have a vacuum gauge hook it up and jump on the highway drive in Oliver drive for a few miles like normal and then try a few miles in drive. I'm sure you will see higher more consistant readings in drive with your current setup. 273 ratios are great highway gears for a 3 speed but the overdriven will like a 3.23 or 3.42 ratio better. As far as city goes the lower numerically higher ratio will help get it moving a lot better as well from a stop and you should see a gain here as we'll if you were to swap gears. But then again city driving is usually a wash with all the stop and go.
1976 Custom Deluxe SWB Med FMB.3/4 Drop.
Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out.
1997 K1500 ext cab 5.7 stock except muffler
SSC's76 is offline   Reply With Quote
Old 03-24-2013, 11:09 AM   #10
bilfman
bilfman's Avatar
Agreed 2.73 with 31's and overdrive is too low rpm to be in an optimum torque/power band. Easiest check for this is as a previous poster mentioned. Try driving in 3rd and see how the mileage goes. If it goes up, gearing is the issue.
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205
1971 GMC 3/4 Ton 4X4
bilfman is offline   Reply With Quote
Old 03-24-2013, 08:32 AM   #11
cleansquare
I have a 2000 volkswagen beetle diesel that is my dd, but with the 4L80e swap in my c20 im hoping to chamge that!
Old 03-24-2013, 08:55 PM   #12
Skunksmash
Skunksmash's Avatar
Guess I won't be complaining about my 14 MPG anymore.
Skunksmash is offline   Reply With Quote
Old 03-25-2013, 03:35 AM   #13
piecesparts
Parts and more parts
piecesparts's Avatar
You can get a set of 3.73, that should fit up to your posi unit. The change should get you back to at least a 14 MPG range.
Frank
Old 04-08-2013, 10:36 PM   #14
INSIDIOUS '86
Exhaust will help much too. My neighbors hate my truck since its practicaly a dragster going Down the road. The *****ed till I had freinds with real dragsters have a cruise in on my street. The now think I am perfectly quiet.
Two mufflers will be as quiet as it is now abouts but will help mileage some more.
Old 04-08-2013, 11:09 PM   #15
Rufton
In many street applications safe WOT air/fuel is approximately 12 but cruise A/F should be around 14. Wideband O2 will likely pay for itself in short order if you know how to jet carb.
What does plug look after cruising several miles then immediately turning off ignition?
Rufton is offline   Reply With Quote
Old 04-08-2013, 11:20 PM   #16
Rufton
RV cam should have adequate torque for good mileage above 1500rpm.
If you don't have a torque curve for your engine then you can download a trial version of engine analyzer pro.
Old 04-09-2013, 11:24 PM   #17
nosfed2
Ok so i drove it to work again and the numbers got me concerned so i am gonna do another test tomorrow. But here they are The First Time i went to the gas station and filled it till it popped and than filled again and it popped real quick so i know it was full. I wrote down the beginning milage which was 40093 and drove it straight to work and back to the same gas station and same pump and wrote down the milage again 40139 and filled it up again till it popped and than filled again till it popped real quick and it used 4.84 gallons which comes out to 46 miles drove and divided by 4.84 which comes to 9.5 mpg so I took your guys advice and switched to 3.73 rear gears and drove it today. I went to the same gas station and same pump and topped it off again doing the same steps as before and than wrote down the beginning milage 40458 and went to work i than went back to the gas station and wrote down the milage 40511 and filled it up again till it popped and than filled again till it popped real quick so i knew it was full and it used 2.78 gallons which comes out to 53 miles this time but i did go to my house and than left for work which added 7 more miles but that comes out to be 19 mpg? that seems like a huge gain but i did notice that i was giving it a lot less pedal and last time on my way home the gas gauge was dropping down to a line below F but this time it never moved from over F? I will test it again because this seems to good to be true...lol
Old 04-10-2013, 03:09 AM   #18
INSIDIOUS '86
It's hard to calculate for sure what your gains are that way. What I've done is take a milk jug and run it to the fuel pump and block of the tank lines and measure out an exact gallon reset my trip meter (i have one (: )Then drive in the city and see how far I get then fill it and go to the highway pull over measure on exact gallon and do it again.
Many varable such as wind and hills but you get much closer to the correct number. Also losing the tailgate helps bunches too as well as electric fans and good exhaust with headers. A sharp tune on the carb with an efficiant intake and your about as close as you can get. Anymore after will net small changes but worthiness is is up to the driver.
Old 04-09-2013, 11:48 PM   #19
Rufton
Where can I get one of those 3.73 gears
Old 04-10-2013, 04:02 PM   #20
piecesparts
My bet is that it will settle out to around 14 MPG.
Frank
Old 04-11-2013, 12:51 AM   #21
nosfed2
Well i drove it to work again today 53 miles round trip and went back to the gas station topped off and it used 3.7 gallons which come out to be 14.32 which is about 5 mpg better than i was getting. So i believe these results now...lol...turns out last night the pump i was on was kicking off early because of the angle i had it at...so today i filled it till i could see it in the neck..lol...and
repeated that step when i went back....well now on the a electric fan and a alternator upgrade..thanks for the help!!
Old 04-11-2013, 01:21 AM   #22
Rufton
Nice.
What rpms gives you the 14mpg?
Old 04-11-2013, 10:31 AM   #23
nosfed2
At 55 mph the tach says 2000 rpm and it climbs up the hills with out down shifting where it was always in and out of gear before. The cam I have in there is a RV cam and it makes its best power at 2000-3000 rpm so I have found that if i can keep it around there as much as possible it helps my MPG..
Old 04-11-2013, 07:56 PM   #24
INSIDIOUS '86
Peak torque is where it's most efficient so your Definitly in the right rpm band.
