Plug and Play LED's
Anyone use these LED's and get them to work?
Mine work until I turn my headlights on. Then no blinkers. Posted via Mobile Device
1971 C/10 - Orange & White 2009 GMC 1500 - Lowered 3/4 22' KMC Slides |
![]() Join Date: Dec 2012
Re: Plug and Play LED's
I am going to give them a shot too. I'll let you know if I have a similar outcome. I wish us both luck..
Just for grins, check your grounds.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11. 1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9 |
I had the same problem with my wife's 66 mustang. Never could get the damn things sorted out. Ended up sending them back and getting a refund. I tried different no-load flashers, cleaning grounds and all kinds of other crap. No luck.
Hope you get it sorted. Just a note. They weren't from the same vendor that is advertising on this board.
67 C10 Stepside 66 Mustang Coupe 99 Burb 2500 Last edited by 67Slider; 03-25-2013 at 10:03 AM. |
Here's the pic again.
Dang I'd like some for my 68!!! Where did you get them from? Thanks
Posted via Mobile Device |
LMC truck. But let me see if I can get them to work first. They are not working correctly. When I turn on my headlight they won't flash.
Don't you have to swap to an electronic flasher?
I thought you did not with these. But, I could be wrong.
LED lights dont not pull as much current as a regular bulb therefore the flasher does need to be changed to flash properly unless the set up has a bult in resistor to draw more current. I had LED's on my motorcycle and had to add resistance because they blinked REALLY fast. LED's also have a polarity that must be followed. Current only runs through them one direction as with most diodes (LED- Light Emmitting Diode) Good luck
72 Chevy LB, LS in the works, 4L80, Grandfather bought it brand new. 66 GMC Short Step, 84 Front Suspension, many more mods to come 67 Chevy 3/4 Ton, 327, Auto, Factory A/C Ya must have been movin cause I was haulin a*$ when I passed you |
The rear LED lights I got you have to buy the electronic flasher to make them work properly
#11 | |
BUT, they work fine until I turn the head lights on. They don't flash at all.
