03-25-2013, 04:02 PM | #1 |
rear end gear ????
hey guys i have 85 c10 shortbed with a 5.3 with ms3 cam from texas speed im running a 4l60e trans ive read where i need atleast a 3200 stall with this cam question i have is my truck currently has 207 gears what gears would you guys recommend to run in the rear end with this cam and stall combo thanks
03-25-2013, 06:27 PM | #2 |
meowMEOWmeowMEOW
Re: rear end gear ????
With a gear ration like that, I'd think you'd want to back down A LOT, unless you plan on building a car to cruise at 80mph. The 3:73, and 4:10 gears are always popular, and since your' running an overdrive trans, either would work for your application.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
03-26-2013, 08:18 PM | #3 |
Yup, 3.73-4.10 is ideal.
I'd also get a looser converter - something in the 3600 neighborhood. |
03-27-2013, 08:52 AM | #4 |
With the MS3 and a 3200 stall, alot of guys run at minimum, a 4.10 gear. To really take full advantage of the cam's potential, a 4.30 or 4.56 gear is recommended.
03-28-2013, 02:27 AM | #5 |
You need to factor in what tire height you have as well.
Custom Painter/Restoration Specialist 1965 GMC 3/4 Ton LB SOLD? 1964 Chevy El Camino in full restoration 1991 Chevy S10 288K+ miles 2nd Owner SOLD 2020 RAM 1500 Warlock |
03-28-2013, 03:23 PM | #6 |
207 gears?
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
03-28-2013, 10:16 PM | #7 |
Truck and auto performance nut
....... or 3.07?
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
03-29-2013, 08:34 PM | #8 |
I run a ms3 in my5.7/m6 67 Camaro swap. it has 373, should have 410. My 2 cents
03-29-2013, 11:18 PM | #9 |
what he said. I've got 3.73's in my truck and wish it had the 4.10's my TrailBlazer SS has. The 14 bolt w/disc brakes would be nice too!
03-29-2013, 11:31 PM | #10 |
I had the stock 3:08"s with the 6.0l...that thing would fly!!...a little more sensible now with 3:42's..... 3:73's are too low for me to be driving daily..
