Carpe manana
![]() ![]() Join Date: Dec 2010
Cab Decals Thread - What Went Where Which Year?
SPID aside, I'm curious what decals went where inside the cab for 67-72 trucks in general and those that are specific to certain options. Were any decals mounted inside consoles?
Here's the decal GM included for the sending unit selector switch specific to the 1970 only rear mounted auxiliary gas tank (KrazyRay and Lemield pics)
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
Re: Cab Decals Thread - What Went Where Which Year?
There is the 72 RPO NL2 fuel tank gauge selector switch decal.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
Carpe manana
Good deal Tim- I believe the 1970 only aux tank was RPO N18
Yep...that's the code....
Larry 1949 Willys CJ2A, Kubota Turbo Diesel engine, Warn Overdrive, 11 inch brakes, 12volt, Warn M8000 Winch "Little Green" 1970 Rustoleum Roller Red C20 Custom Camper 454 TH400 "Big Red" 1971 K20 6.2 Turbo Diesel 4x4 4spd Ranger Overdrive "Pumpkin Wagon" 2005 VW Beetle Diesel 44+ MPG "Silver Bullet" |
I remember seeing a sun visor decal-
(Not mine, stolen from another thread)
71 K20 64 GMC mud truck |
Carpe manana
Nice - A 1972 only decal on driver side visor
Here is a better picture of the engine starting proceedure.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban Last edited by SS Tim; 03-28-2013 at 12:01 PM. Reason: cropped picture to fit |
#8 | |
#9 | |
Carpe manana
Anyone have pics of correct location(s) for posi decals?
#10 | |
Also here is a clip from the GM accessory dual saddle tank installation sheets provided by jocko. It shows the LEFT MAIN RIGHT positions for the gauge selector switch. Here is a rocker sill panel picture of a N18 truck fuel valve and placard. Originally posted by special-k. On the posi. warning decals IIRC they were found either at jacking information sticker or inside the console. Need to check the assembly manual and see what I can find on that.
