Old 03-26-2013, 01:07 PM   #1
hfd410
hfd410's Avatar
72 cab with TX title
72 super cheyenne cab. This is a heater cab with after-market AC installed by "Tornado" manufacturing in Ft Worth TX. I am leaving the heater unit, AC unit, brake pedal and booster in the cab, unknown conditions. Tank is in cab also. VIN plate intact. It has the normal outer rocker issues, worse on passenger side. It has about a 4 inch rusty spot on the upper windshield channel on the passenger side and the worse part is that my sling slipped and dented the roof on both sides above the doors. This is a nice repairable cab off of a truck that I parted out. Picked up only, $250.
hfd410 is offline   Reply With Quote
Old 03-26-2013, 01:10 PM   #2
hfd410
hfd410's Avatar
Re: 72 cab with TX title
can a moderator please move this over to the parts board? My mistake...
Old 03-26-2013, 01:26 PM   #3
hfd410
hfd410's Avatar
wow I must be exhausted. Please move to the PICKUP parts board...
Old 03-26-2013, 05:08 PM   #4
POS1
Well, at least you caught your mistake!
- Brian
FleetFilter.com
1991 Chevrolet V1500 Suburban 4x4
1986 Jeep CJ7
1969 Porsche 911S Targa
POS1 is offline   Reply With Quote
Old 03-27-2013, 09:51 AM   #5
hfd410
hfd410's Avatar
yeah I'll probably wad it up with the tractor and haul it off. Live and learn....
Old 03-27-2013, 10:24 AM   #6
TBONE1964
Cluster King
TBONE1964's Avatar
PM me if you are going to scrap it Bryan. I am interested in some sections near the rockers if you have a way to cut them off.
Thank's
TBONE1964 is offline   Reply With Quote
Old 03-27-2013, 10:55 AM   #7
ChevyCruizer
17's too small
ChevyCruizer's Avatar
i am also interested in some parts if you are going to scrap it. Sending a PM...
68 C10 SWB SS 5 lug power disc brake conversion 2.5 inch drop spindles van tilt column Air Ride Technologies Cool Ride air bag kits Performance Online tubular upper control arms and shock relocator kits ECE super track panhard bar 1 piece side windows
ChevyCruizer is offline   Reply With Quote
Old 03-27-2013, 12:44 PM   #8
hfd410
hfd410's Avatar
What would you need off of it Tbone ?
Old 03-27-2013, 01:21 PM   #9
TBONE1964
Cluster King
TBONE1964's Avatar
Kind of a strange request and I will understand if you don't want to fool with it.
First of all, it has to have the factory rocker panels for this to work for me.
I need the area of the cab at least 3 inches above where the rocker is spot welded and at least 3 inches of the rocker below the spot weld or split, both front and rear on left and right sides.
What I am trying to accomplish is to put aftermarket rockers on my truck and make them look factory. My truck has had the rockers replaced and who ever did it just welded the seam solid.
I want it to look like factory and these pieces will give me the section with the factory spot welds and I can graft new rockers to those pieces. It sounds much more complicated than it is.
If you are interested, maybe I can have some one help me draw a line(s) on a photo to show you where to cut.
Thank's
Tom
Old 03-27-2013, 05:22 PM   #10
hfd410
hfd410's Avatar
That makes sense, those areas are good on the cab. I will PM
Old 03-27-2013, 09:05 PM   #11
TBONE1964
Cluster King
TBONE1964's Avatar
Thank's Bryan
Old 04-02-2013, 02:06 AM   #12
Vintageperformance
Hi do you still have your cab for sale? Was it a shortbed truck? If so I am interested
Vintageperformance is offline   Reply With Quote
Old 04-02-2013, 02:22 AM   #13
Vintageperformance
Hi actually I guess what I wanted to know is if its a 2wd 1/2 ton v8 cab. And. How far from Austin are you. Thanks
Old 04-02-2013, 08:45 AM   #14
hfd410
hfd410's Avatar
Cab is no longer with us thanks for everyones interest.....
