Old 03-26-2013, 05:53 PM   #1
jknopp59
1978 Chevy wont get fuel
I replaced the fuel pump on my 1978 chevy and its not getting fuel to the fuel filter. I blew air through the fuel lines from the tank and still nothing, what should I try next.
jknopp59 is offline   Reply With Quote
Old 03-26-2013, 06:49 PM   #2
Oilbrnr
Oilbrnr's Avatar
Re: 1978 Chevy wont get fuel
inspect/replace the rubber fuel feed lines.
-Don-
'66 C10 w/factory A/C
'77 Cheyenne K5 350/465/205
'80 Custom Deluxe K20 350/465/205
'04 Denali XL
'05 DMax CCLB 4x
Have a Hickey Sidewinder Winch and need the owners/install manual? Send me a PM with your email address and I'll forward you a .pdf
Oilbrnr is offline   Reply With Quote
Old 03-26-2013, 07:32 PM   #3
jknopp59
They aren't in the best condition, if they are worn at the end could it lose suction? I don't know if there is any fuel going to the fuel pump at all, is there any way to tell if there is a whole or something in the fuel lines without taking them off?
Old 03-26-2013, 08:01 PM   #4
Oilbrnr
Oilbrnr's Avatar
not generally at the very end, but if there are any cracks or rodent caused trauma it will cause issues. You might want to put a signature in stating what your truck is so that we'd have an easier time helping you troubleshoot.
I had a packrat gnaw at the tank to hardline on my K5. Punctured it just enough so that the pump wouldn't prime. Luckily I was able to replace it without dropping the tank.
-Don-
'04 Denali XL
'05 DMax CCLB 4x
Old 03-26-2013, 08:25 PM   #5
jknopp59
Its a 1978 chevy 3/4 ton 4x4, Ill probably check all the fuel lines and see what I can find. I feel like there is hole or something in the line somewhere because when I blew air through the hose I could here it from the gas tank.
Old 03-28-2013, 11:50 AM   #6
motornut
78K & 79C Jimmys
motornut's Avatar
you can try to syphon from the feed lne
keep the recieving "can" low to the ground
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
