Old 03-29-2013, 01:08 AM   #1
Tdubbyount
Tdubbyount's Avatar
Uhh...Anyone else running hydroboost???
Ive got a 79 k10 swb that came factory with hydroboost brakes (came w/ 5.7 olds diesel) and the brake booster needs replaced...But im having a little trouble finding the correct one. Niether Napa or Orielly's had the part listed under my truck, so i came up with a part number for a '79 and had one ordered. However, it wont work. As you see in the picture, the new one came without the piston spring and baffle and spring retainer, so i pulled it out and tried to re install it on the new unit, but there was a substantial bore size difference between the two. Like 3/8 of an inch. Makes no sense. How many different units are there? Anyway...I have a different one on the way, no clue if it will work, i just found one that had a different part number. So we'll see. I'll try to get more pics up. Any help is appreciated
1976...no...79...Chevy....wait...GMC shortbed 4x4. 5 inch lift on 35s, 355, sm465, daily driver. One day I'll figure out the story in that one.
1957 Chevy long stepper...not sure what I'm doing with that one yet. Awaiting funds I suppose.
Tdubbyount is offline   Reply With Quote
Old 03-29-2013, 09:59 AM   #2
68Timber
I know the pieces fit
68Timber's Avatar
Re: Uhh...Anyone else running hydroboost???
Try rockauto.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 03-29-2013, 11:57 AM   #3
Tdubbyount
Tdubbyount's Avatar
Same PN as the one i already bought. The other one came in today and its wrong too.
Old 03-29-2013, 12:13 PM   #4
csb#356
The only difference I knew of was when they switched from flare fittings to o ring fittings sometime around 80'. Maybe there is a difference in bore size from 1/2 to 1 ton. Are the ones your getting to small or to big.
csb#356 is offline   Reply With Quote
Old 03-29-2013, 12:18 PM   #5
Tdubbyount
Tdubbyount's Avatar
The ones im getting are too big. All of the fittings are the same and it bolts right up on the firewall side, but the rod assembly for the master cylinder is too small for the new one.
Old 03-29-2013, 08:47 PM   #6
Tdubbyount
Tdubbyount's Avatar
Screw it. I'm converting to vacuum.
Old 03-29-2013, 08:52 PM   #7
68Timber
68Timber's Avatar
I'd dig a little deeper to figure it out. The hydraboost works better plus you'll have to create a vacuum source to swap.
John
74 Honda Z50 build
Old 03-29-2013, 09:17 PM   #8
Tdubbyount
Tdubbyount's Avatar
I've already got parts on the way. A new p/s pump, vacuum booster and master cylinder, and hoses. I may need a different pushrod but I'm not sure yet. I got tired of trying to chase down parts for that system. The diesel 350 was pulled out years ago and I recently put a fresh 350 in it, so it will have all the vacuum it needs.
Old 03-29-2013, 09:02 PM   #9
Shyguy
Junior Member
Shyguy's Avatar
We just picked up a '75 C-30 and it has hydro boost brakes.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 03-31-2013, 12:34 AM   #10
Tdubbyount
Tdubbyount's Avatar
Swapped everything over today. Still have no pedal. Darn. Did a complete flush of the brake fluid and power bled all four corners. Very little improvement. Booster and master cylinder work fine. Last thing I can think of is calipers?
It also pulls hard to the right under braking. New problem that just came up today.
Old 03-31-2013, 12:42 AM   #11
68Timber
68Timber's Avatar
This is really hard to diagnose with that many changes going on at once. Unfortunately China is making it worse for us, lots of master cylinders are bad out of the box.
John
74 Honda Z50 build
Old 03-31-2013, 04:23 AM   #12
Tdubbyount
Tdubbyount's Avatar
We disconnected the brake lines from the master, plugged the holes and tried it and the pedal was very firm while running. That rules out a bad cylinder or booster. Power bled everything. Still no pedal. I'm absolutely sure there's no air in the lines. We have good pressure at all four corners so the proportioning valves are fine. I'm thinking calipers. Wheel cylinders aren't leaking either.
Old 03-31-2013, 10:27 AM   #13
68Timber
68Timber's Avatar
Pulling hard right makes the left front brake line suspect.
John
74 Honda Z50 build
Old 03-31-2013, 01:37 PM   #14
Tdubbyount
Tdubbyount's Avatar
I recently put on skyjacker stainless brake lines, and there's good pressure on either side.
Old 03-31-2013, 03:05 PM   #15
csb#356
If the whole system was open like that, you're probably better off just letting it gravity bleed for a while. Having air in the lines could make it pull like that.
Old 03-31-2013, 03:10 PM   #16
INSIDIOUS '86
INSIDIOUS '86's Avatar
Rebuild kit http://www.piratejack.net/index.php?...emart&Itemid=6
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
