03-29-2013, 07:45 PM | #1 |
my battery keeps draining!
So my battery drains while truck is running. Replaced voltage regulator and had alternator abattery tested twice. What is draining the battery! ?! I cant figure it out
Posted via Mobile Device |
03-29-2013, 08:13 PM | #2 |
Re: my battery keeps draining!
are you sure you are getting 14 volts to the battery?? did you do a load test on the battery?? just to make sure it is good? I wonder if the voltage regulator needs to be polarized???
03-29-2013, 08:14 PM | #3 |
03-29-2013, 09:16 PM | #4 |
What do you mean it drains?
What exactly is it doing to make you think it drains? |
03-29-2013, 09:24 PM | #5 | |
03-29-2013, 09:36 PM | #6 |
Eliminate all the extra power draws on your motor.
What compressors? Could be to much draw on your charging system. |
03-29-2013, 09:41 PM | #7 | |
03-31-2013, 01:17 AM | #8 |
Can you tell me what you found? My truck drains the battery if I don't drive it for a day or two. I know the alternator is charging. After looking into it more, I discovered that the battery doesn't drain if I disconnect the baffle connector for the headlights that's near the voltage regulator. The good news is that it seems to be forward of the radiator support. The bad news is that I have to find it! Any info you can give me on what you found with yours would be great.
04-01-2013, 11:33 PM | #9 |
Very cool. Good luck!
03-31-2013, 01:28 AM | #10 | |
03-31-2013, 01:52 AM | #11 |
Keepin it old school
03-31-2013, 02:03 AM | #12 |
Thanks again. I don't want to hijack this thread, but I originally suspected the horn relay too. Totally removed it from the circuit and I still have a draw on the battery. The only way I can get it to go away is by disconnecting the headlight connector on the radiator support.
03-31-2013, 11:32 AM | #13 | |
04-01-2013, 11:09 PM | #14 | |
How is yours doing? |
