03-29-2013, 07:55 PM | #1 |
vss help
I am having a hard time with my vss. I cant get it to read much speed. It really does not start reading tell 10-15 miles a hour. I have a dakota digital 8k pulse generator on my speedo cable port on the transfer case. I told the ecm guy that is what i have. He said he changed it in the ecm from 4k to 8k. So i figure even if he did not change it it would read to fast not to slow. At 60 mph my ecm reads 3 mph. Any ideas?
82 c10 5.3/4l60 84 c20 5.3/sm465 85 chevy k10 suburban LQ4/4l60 91 chevy c10 suburban Lsa 5.3/4l60 2017 Silverado whipple 5.3 1964 Vw beetle 1974 vw beetle |
03-29-2013, 08:52 PM | #2 |
Re: vss help
Double check your wiring, at vss I had that problem.
03-29-2013, 08:54 PM | #3 |
Re: vss help
I have looked at my wires. The vss has 2 wires and the pulse generator has 2. tryied it both ways and no change.
03-29-2013, 11:27 PM | #4 |
Truck and auto performance nut
Re: vss help
if the ecm is looking for an 8k signal but only gets a 4k wouldn't it read slow? and a 2k signal would read even slower?
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
03-31-2013, 05:50 PM | #5 | |
Re: vss help
What you're really interested in is the VSS input. Specifically, what you want to change in the ECM is the number of pulses per driveshaft revolution. I'm assuming that you have a manual transmission tune in your ECM, so the default value is 17. I can't tell you what to change it to without knowing your tire size and rear gear ratio, but here's an example for 4.10 gears and 30 inch tires: 1) You need your tire circumference. That's just the tire height times 3.14159. For 30 inch tires, that would be 30 x 3.14159 = 94.2477 inches. 2) Figure out how many times your tire turns in one mile. There are 63360 inches in a mile, so divide that by the circumference from step 1. For 30 inch tires, that would be 63360 / 94.2477 = 672 tire revolutions per mile. 3) Now we need to know how many times your driveshaft spins in a mile. That is just your rear gear ratio times the number of tire revolutions from step 2. For 4.10 gears and 30 inch tires, that would be 4.10 x 672 = 2755 driveshaft revolutions per mile. 4) Last, we can finally figure out how many pulses per driveshaft revolution that your setup is producing. From step 3, we know that for 4.10 gears and 30 inch tires, the driveshaft is spinning 2755 times per mile. We also know that the Dakota digital box puts out 8000 pulses per mile. So, 8000 / 2755 = 2.9 pulses per driveshaft revolution. The 2.9 pulses per driveshaft revolution from the calculations above is the number that needs to replace the default 17 in the case of 4.11 gears and 30 inch tires. If you didn't change it, the ECM would be seeing about 17% of actual speed. In other words, the ECM would think you were going 10.2 MPH when you're really going 60 MPH. I hope that helps. Just post your gear ratio and tire height if you need help with the math for your actual setup. |
03-31-2013, 06:10 PM | #6 |
Re: vss help
4.10 gears and 32.4 tall tires. Thanks.
03-31-2013, 06:53 PM | #7 |
Re: vss help
03-31-2013, 07:03 PM | #8 |
Re: vss help
Wow. Thanks
03-31-2013, 11:49 PM | #9 |
Re: vss help
very good info dayj1!
04-01-2013, 06:01 PM | #10 |
Re: vss help
Well I got a hold of my harness guy and he is sending me a new ECM. The one he sent me with my harness has a 4l60 tune in it somehow. He is sending one with a manual tune. I told him about the pulse per revolution thing and I hope he fixed it. Hopefully my truck stops stalling every time I move around slow. I guess we will see. Thanks for everyone's help. I will get it dyno tuned in a few weeks so maybe they can make it exactly on the speed.
04-01-2013, 08:50 PM | #11 | |
Re: vss help
04-01-2013, 10:19 PM | #12 |
Re: vss help
That is what we are thinking. I have found a place to have it tuned so if not I am sure the tuner can figure it out.
04-06-2013, 12:05 PM | #13 |
Re: vss help
ECM got here today. Can't wait to test it out!
04-01-2013, 08:44 PM | #14 |
Re: vss help
there are places in the tune for idle that is tied to speed not just rpm. I wouldn't be surprised if this ecm swap (if it corrects your drivetrain issue) cures, or at least improves upon... your problem.
04-06-2013, 02:07 PM | #15 |
Re: vss help
thats one of the nice thing about having hptuners...I can look at things and try to mess them up.
04-06-2013, 10:25 PM | #16 |
Re: vss help
I would love to have a program to mess with things but all I am sure I would do is make it worse. I for sure would not mess with any fueling or timing tables.
04-07-2013, 02:55 PM | #17 |
Re: vss help
nice thing about it......you can save the file with diff names and just go back and load up the previous or original one if...well, things go bad.
and yes........I'm afraid of those tables too. I'll change the rpm and speed limiters, shift points, a/f ratio, things like that... and have considered getting into torque management and dialing it back a hair. There are LOTS of tables that are greek to me. in reality...........I have it so I can log runs to send to my tuner so he can review/modify and send me a new tune to load up.
04-07-2013, 03:04 PM | #18 |
Re: vss help
I was looking at those programs and they are not as pricy as it thought. I can get hp tuner for like 500 bucks. Really thinking about it.
