Gauge pics
Does anyone have any close up shots of Autometer gauges mounted from the outside of the bezel? I guess you would probably call it top mounted. Not like Swervin's, I would call his bottom mounted. Even though his gauges are bad a$$, I don't think I enough patients to do mine like that.
Gary -1986 SWB: lowered 4/6, SOLD!!! -Best 1/4 mile: 14.51 @ 91.01 MPH -2001 Pewter Tahoe, billet grill, Corsa Sport Cat-back, K&N FIPK SOLD!!! -2004 Z-71 Extended cab with a flowmaster, BDS 6.5", 3" BL, 35x12.5x18 Trail Grapplers on Pro-Comp 18x9 wheels |
yeller
Eddie has his done that way...maybe his slacker butt will chime in!
![]() ...Jeff |
There's a couple on here, but not sure if they're are close enough for you.
![]() http://www.shelbournes.net/trucksite...iors/index.htm
Scott Shelbourne |
Thanks Scott, but I really need something a little closer.
Scott has pictures of mine on that link and if you click them they will get a little larger. Let me know what you are looking for as far as details or something and I can post some pictures or email them to you depending on the picture size.
<-------- Been slackin' online, but getting a lot of work done ![]() ![]()
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION * |
Yeah Eddie, I want to install mine the way your's are. I already have the fuel gauge in, but wanted to see how it compares with some others. IF you could email a couple of pics to devall@cox.net I would really appreciate it.
You've Got Mail
Eddie,
Did you use the stock bezel, or did you just put in a piece of plastic and cut it? |
stock bezel
ShadeTree Kustomz
is this what you are talking about
Yeah that's it. Where did you get the billet from? Thanks.
ShadeTree Kustomz
i got it from trenz but i orderd it through a local custom shope it cost about $100 but you have to make the holes bigger to fit the guages in them.
They have polished and brushed finish.
Make sure you get the one you want. Everyone sells the brushed, but I guess the polished are harder to find. Contact Swervin for info on the polished one.
Alleged Member
Phoenix, it appears that your gauges point directly forward as opposed to upward towards the driver. If this is accurate does it affect how well you can see the gauges?
#15 |
Alleged Member
Sorry my previous post was for 82 chevystep
#16 |
ShadeTree Kustomz
they do point straight forward and i can see all of the guages fine. hope that helps.
#17 |
Slots go on anything!
are those 2 5/8 gauges or 2 1/16 for the small? I am guessing the larger ones are 5"?
1974 Jimmy- 5.3/4L80e/NP241 |
#18 |
yeller
they are 2 5/8" I believe.
#19 |
81, that looks awwsome
2004 Silverado Crewcab (Dark Spiral Gray) |
#20 |
91 SWB 383
here the pic of mine . it u go to the web site there is a few more
96 2dr Tahoe protruning LS1 347/4L60L, PSI harness, body dropped, 4link, 6lug conv, narrowed rearend, Schoenfeld headers, 2600 stall, 317 heads milled .040, http://photobucket.com/albums/q169/k...ahoe prostreet |
#21 |
91 SWB 383
this will tell what gauges i use and part numbers
http://www.mychevytruck.com/showowne...&n=84329&pos=3
