How much damage .
I was on the highway doing around 65 when i reached fir the radio and moved the shifter lever down to 2nd gear. How much damage did i do to my transmission it feels weaker than how it was. my truck is 1985 350/350 combo Thanks for the responses and happy easter
Posted via Mobile Device |
Re: How much damage .
Seems like it should be ok to me. You should be able to do 65 mph in second gear, plus the potential damage would be from over-reving the engine (rather than your trans - which doesn't seem likely).
Give it a few days and see if it is just your imagination. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
Thank you sir for the reponse the shop guys told me the same thing but it feels weaker and sounds a little funny but might be my imagination about worring and over thinking it. The truck just hit 40000 miles on both eng and trans
I agree with Keith, that engine damage would be more likely than messing up the tranny. Its probably your imagination cause that seems to be a big culprit with most noises and feelings with the vehicle.
1979 ![]() 1996 Silverado x-cab "the daily" |
Addicted to Rust
![]() Join Date: Dec 2009
I knocked may last Turbo 350 into reverse at about 45 and it lived. You are imagining things. Jay
Current trucks: (48 GMC100 320 inliner) Gone (48 Suburban in pieces) Sold 87 GMC CCSB 5.3 4l60E Daily Driver ECTA National record holder XO/PP We never really grow up, we just learn how to act in public. |
I've hit mine into park a couple of times while moving (after the engine had died and I needed to re-start) and it's still here.
Michael Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9 |
Yeah im with Keith over reving your engine would cause more damage faster then knocking the trans down a gear.A turbo 350 is a pretty strong trans even stock i wouldn't worry about it just don't do it again lol.
Parts and more parts
You know hitting reverse at 65 is something to worry about, but I have done it in the past. That is why I now have floor shifters with a positive lock for going into reverse. Dropping into second at 65 is not that bad, and it may have shaken you up more than the truck.
Frank |
this must be a common problem with these squares, i knocked mine into neutral on the highway while messing with the radio too.
1977 srw cc lb 396/700r/4:11's/6'' bds lift/ 35's. sold 1986 suburban 350/700r/3:73's 31's: parted out. 1980 silverado swb 5.3/700r/ 2'' drop/ daily driver. sold 1985 c10 long bed 5.3/700r/2'' drop/17" wheels/ daily driver. sold 1970 c10 long bed-new project! getting ready for the 6.0 |
accidentally down shifting from 3rd to 2nd???.....isn't that what happens when passing??....3rd to 2nd is nothing...doin 65 and hitting reverse or park now that's a little different!
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
#11 | |
On a Automatic 2nd shift with the lever in Drive....Only the Intermediate clutches apply & the Sprag will overrun if you let off the gas. |
