06-19-2003, 08:39 PM | #1 |
61 rear ends
I have recently purchased a 61 Apache shortbox fleetside.I have been reading about the rear end swaps.I have a rusted all to hell 71 c-10.Yes both trucks have the original rear end.I measured the rear end in it and theres no way it will bolt in.I have some hollander books and 61-62 have a different rear end than the rest.I read about the chevy duty rear end kit.Do they have a webpage?Is there a rear end that fits or will I be better off to get a ford 9" and have it made to fit?Has anyone changed there rear end in a 61?
08-15-2003, 11:30 PM | #2 |
I would also like to know, especially since the eaton is not a popular rear
62 c10 short fleet 350/350 dropped 87 toy: SAS 35" MT/R's, 5.29's, detroit rear, exocage |
08-16-2003, 03:55 AM | #3 |
C10 now is a GMC
Hi BadCo, Xextr3m3, and welcome from Calirfornia
americanclassic.com has a link were you type in you vin, and it gives you a list of what options were from the factory like trannies, engines, rear ends, etc. ChevyDuty has a website, it's chevyduty.com. The 1960-62 trucks had torsion suspension, and was change in '63 to coils up front, and the frame rails are spaced differently from the 60-62's. David
*1962 C10 swb fleetside, big window, custom cab 350/TH350 combo...Hot Rod *1963 C10 lwb fleetside, small window 230/4 speed...Blvd Cruiser *1931 Ford 5 window coupe (soon to be Hot Rod)... Father & Son project |
08-16-2003, 12:49 PM | #4 |
454 club
Welcome from Texas.
David 1965 Chevrolet c-10 454 automatic Custom bbw swb. 1965 Chevrolet C-10 swb (Sold) 1963 Chevrolet C-10 6 Cyl automatic with dual exhaust, pb, ps and 17's. R.I.P "I will miss you. 1967 Chevrolet C-10 6 Cyl Custom lwb 1939 Chevrolet Coupe, 350 v8 automatic. 1935 Chevrolet 2 Dr Standard in the works. 2015 Harley Davidson Street Glide. 2023 Chevrolet Stingray Z51 Convertible. I never want to grow up. |
08-18-2003, 08:19 PM | #5 |
I have a 61 short fleet. I have changed the rear end out on mine. However I also changed to a 63 style frame. I cut off the trailing arms and removed the entire rear end assy. I then used the entire leaf spring & rear end assy from an 82 chevy. I am not sure about the difference in widths between the 61 and 63 style frames. At the same time I swapped the whole front cross member from the same 82. In the end I had to slightly modify the leaf spring hangar brackets on the front only and the front cross member matched up 5 out of 7 holes on each side with the other 2 only 1/2 hole off. Results: 5 lug wheels, front disc brakes and power steering. Dont know if this helps, but there are a lot of options.
Phil
61 short fleet 69 C10 97 Astro Van |
