Best way to do a 5/6 drop?
hey guys i was wondering whats the best way to do a 5/6 drop?
what brand is the best? does buying all the same brand for the parts makes a difference? will the wheels rub if I would put 15x10 all around? are there cons on doing a 5/6 drop? pictures will be nice |
Re: Best way to do a 5/6 drop?
The easy way is a good spindle spring combo with a flip kit, shock extenders, and good shocks. My preference is KYB.
The thing I have never been a fan of flip kits because of the bracket they give you. Personally I prefer new perches, u-bolts, and 1/4 plate for the bottom bracket. Then I shorten my drive shaft 1/2-3/4 of an inch, but most Chevy trucks I have been under seem to be able slide the carrier bearing back enough. That is if you have a long bed. Buy the same brand helps for a bit of a discount, but some people like different parts of different kits. 15x10's get kind of wide for the front, but you won't know till you get there. Or if you have the back spacing to see how someone else has done it. The only cons is you now have to drive around like a car, and loading the truck up heavy now requires air bags. |
#3 | |
2.5-3" spindles & dropped springs (cut 1-coil if on a budget; purchase drop springs if within budget).
For the rear do a Bell Tech or Western Chassis flip kit & shock extenders. I would recommend doing c-notches to ensure there's no bottoming out on the frame rail. Good quality shocks front/rear & make sure you have a sway bar up front w/some good bushings.
does it make a difference if i cut the oem springs than buying aftermarket lowering springs?
whats better 2.5 springs/2.5 spindles OR 2" springs/3" spindles for the front? |
whats do lowest i could go with out having to do a notch in the back?
anyone? |
#7 | |
I typically try cutting a coil 1st. If I don't like the ride quality, I look for aftermarket springs w/higher rate. 3" spindles run into more back-spacing problems on wheels. It depends mainly on that for me. 2.5" units seem to have fewer issues. The 'how low can I go w/o a notch' question is subjective @ best. Ask 6 guys & you'll get 5 different answers. If it's used as a truck & hauls heavy-ish items in the bed, plan for a notch & eliminate worries. If it's only a part-time, looks-only vehicle, follow the same philosophy as the front coil thing.... try it 1st w/o the notch.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 04-05-2013 at 08:49 AM. |
Going that low, a C-notch kit is also recommended so your rear-end isn't constantly bottoming out on your frame.
Watch out for your cornhole !
![]() Join Date: Jun 2003
I did the 12 dollar flip kit to mine. The saddles came from Summit. When I did it I removed the factory snubbers. No notch. I like it fine. I have a dually for pulling real heavy stuff.
Posted via Mobile Device |
so all the stuff i need to do a 5/6 drop are
Front: Drop Spindles 2.5 Springs 2.5 Rear: Flip Kit one more thing im missing? |
Diggin The SquareLife
right...but ya also might want to pick up some shock extenders for the rear
will i need to buy any other extra stuff like bolts,grease or anythingg like that?
I heard bad things bout their flip kits but the spindles were alright. Only issue is I had to do quite a bit of grinding on the spindles to get them to fit properly.
1983 Chevy lwb: 400 sbc destroked to 377, comp cams xe 268, Holley Street Dominator Intake, Holley Street Avenger 670 cfm, headers, flowmasters. SOLD 1998 Trans am, mostly stock with magnaflow catback My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=454329 |
#15 |
i am running the djm flip kit and imo its a great kit for the price. I had 0 issues with the install. personally i am running a set of drop springs up front along with a flip kit and 2'' helper springs out back. I plan to remove the helper springs and install a set of 2.5 spindles up front with the hopes of getting my ride quality back a little. Right now its like a wagon.. haha
