Old 04-02-2013, 11:40 PM   #1
1985_C10
1985_C10's Avatar
lowering question
i want to lower my truck a bit. the question i have is how low can i drop it without having to do any body modifications. thanks to anyone who has any answers for me.
1985_C10 is offline   Reply With Quote
Old 04-02-2013, 11:43 PM   #2
Ziegelsteinfaust
Re: lowering question
5/7 or 6/8 depending on how settled your springs were to begin with. All you would need to do is notch the frame in the back a bit.
Ziegelsteinfaust is offline   Reply With Quote
Old 04-03-2013, 12:15 AM   #3
1985_C10
1985_C10's Avatar
i know nothing about lowering. i know what you mean by notch the frame, but what does that need to be done for?
Old 04-03-2013, 12:40 AM   #4
Ziegelsteinfaust
https://www.google.com/search?q=fram...w=1600&bih=775
A bunch of picks of notches.
Old 04-03-2013, 12:45 AM   #5
1985_C10
1985_C10's Avatar
how much could i lower it without doing frame notches
Old 04-03-2013, 03:24 AM   #6
piecesparts
Parts and more parts
piecesparts's Avatar
3.5" in the front and 4" in the rear can be done without cutting into the frame.
Frank
Old 04-03-2013, 09:35 AM   #7
J Knight
J Knight's Avatar
5/5in without notching the frame but it will have a rake. 3/5in if you want it to sit level. If you want it more than 5in in the rear you will need to c-notch the frame for suspension travel(axle to frame clearance), you will need a bare min of 2in for that.
John
82 Chevy Silverado 350ci/TH350
J Knight is offline   Reply With Quote
Old 04-04-2013, 01:52 AM   #8
1985_C10
1985_C10's Avatar
how much has your truck been lowered? i like how that looks.
Old 04-04-2013, 09:47 AM   #9
rs74
rs74's Avatar
I dropped mine 4/6 and was told I shouldn't have to notch it. I have 2.5 drop spindles, 1.5 drop springs and a rear flip kit all from Western Chassis. My truck is in pieces so I can't really say much until I get all the weight back on it and put it back on the road. There are alot of threads on this subject. Take some time and do a search. Then you can see what they look like with the drops they have on.
Roy
85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818
1987 R10 shortie
rs74 is offline   Reply With Quote
Old 04-04-2013, 10:24 AM   #10
Low87
been here longer than Liz
Low87's Avatar
You may have to notch it. I know you can go 5" in the back without a notch, but that's shackles & hangers. Flip kit should give you 6" PLUS puts the axle closer to the frame. I'd be surprised if you made it without notching.
1985_C10, here's mine at 3/5 way back in the day;
~Greg~
Mac's Garage
'87 SWB 6/8 drop "Piso"
'08 CCSB Silverado DD
the departed
'89 GMC K5 Jimmy 4x4 "Rusty Nuts"
'77 Chevy K5 Blazer 2wd
'83 Chevy stepside
"You get what you pay for" - Mike 'swervin ervin' Ervin
Low87 is offline   Reply With Quote
Old 04-04-2013, 10:30 AM   #11
J Knight
J Knight's Avatar
Originally Posted by 1985_C10 View Post
also what is the best way to do the 3/5 drop?
2.5in drop spindle, 1in drop spring, flip kit, and shock extenders. This will give you a 3.5/5in drop.
Thanks, its lowered 4.5/5in. Im going to drop the rear 2 more inches with drop shackles to level it out.
John
Old 04-04-2013, 03:36 PM   #12
BVANT1
This is my 79 lowered 4.5 in the front and 6 in the back before I dropped it another 3 inches in the back. As long as you are running your stock leafs in the back you should not need to notch it. In this picture there is still a few inches of travel before the frame would hit. Some good bump stops and you should be OK.
BVANT1 is offline   Reply With Quote
Old 04-04-2013, 03:39 PM   #13
rs74
rs74's Avatar
Bump stops? I already cut my rear stops off. lol I like the way your truck sits in that pic.
Roy
1987 R10 shortie
Old 04-03-2013, 01:06 PM   #14
Ziegelsteinfaust
Any exhaust shop can install a notch, and from what I have heard from friends are the cheapest places to do it.
Old 04-04-2013, 01:49 AM   #15
1985_C10
1985_C10's Avatar
i dont want to drop it real low though. i think the 3/5 would be good. i just want it a little lower. thanks for the answers guys.
Old 04-04-2013, 01:50 AM   #16
1985_C10
1985_C10's Avatar
Old 04-04-2013, 08:30 PM   #17
lilpoindexter
lilpoindexter's Avatar
I did 4.5" on mine, 2" springs, 2.5" spindles, stock size tires...they rub the inner fenders when I smash into a dip. It has DJM front springs which i think might have settled and gotten a little softer in 2 years...or I'm just hitting bumps too hard. I flipped the back, and i gots a little rake which I'm not that fond of. If i did it again, i would only do 3.5" total on the front. I might swap the springs one day when I quit making excuses as to why I haven't done it.
lilpoindexter is offline   Reply With Quote
Old 04-04-2013, 08:54 PM   #18
school boy
school boy's Avatar
2.5 drop spindles, 3" springs for front. Flip kit, 2" drop shackles rear with bump stops removed. Axle is about 1.5" from frame. No notch
school boy is offline   Reply With Quote
Old 04-04-2013, 11:49 PM   #19
1985_C10
1985_C10's Avatar
thanks guys for all the responses. i think im gonna do a 3/5
Old 04-05-2013, 12:02 AM   #20
1985_C10
1985_C10's Avatar
i was looking at the parts for lowering and i dont even know what to get. what would be a good brand thats not too pricey.
Old 04-24-2013, 03:22 PM   #21
1985_C10
1985_C10's Avatar
Well I'm still trying to decide what I want to do with my truck but just to throw it out there in case I want to do this, how could I raise the front of my truck to make it sit level instead of lowering the back.
Old 04-24-2013, 03:29 PM   #22
Low87
Low87's Avatar
Cheaper to lower the back 2" to level it out. Get 2" shackles or hangers.
~Greg~
Mac's Garage
the departed
'83 Chevy stepside
Old 05-08-2013, 01:49 AM   #23
1985_C10
1985_C10's Avatar
bump...
Old 05-08-2013, 07:05 AM   #24
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
If you want to lower it three inches in the front, just buy a 3 inch drop spindle and be done with it.
Tx Firefighter is offline   Reply With Quote
Old 05-08-2013, 09:48 AM   #25
zook
zook's Avatar
spindles & springs up front flip kit on rear. cut half of bump stop off and is fine.
zook is offline   Reply With Quote
