Old 04-03-2013, 09:58 AM   #1
Gregsenne
Truck sits unlevel after lift
I have a 1986 K20 short bed, 35" tires, 10 bolt front and 14 bolt rear. Front has 6 inch lift springs, the back has a 6 inch lift block with half ton springs.
From the top of the front tire to the fender is 13 inches, but on the back tire, it's 8 inches. The truck is VERY unlevel, and it's VERY noticeable.
I know it will sit higher in the back if I put 3/4 ton springs on (which I'm going to), but it's not going to raise it 5 inches.
Why am I so unlevel? The truck didn't sit unlevel before I lifted it. If I lifted each end 6 inches, I'm struggling to understand why I'm 5 inches lower in the back now than in the front. (But when I lifted it I also swapped tires(33s to 35s), both axles(6 lug to 8 lug), springs and shocks. So pretty much everything under the frame was swapped when it was lifted)
Thanks,
Greg
Gregsenne is offline   Reply With Quote
Old 04-03-2013, 03:32 PM   #2
canadian trucker
A day should have 30 hours.
Re: Truck sits unlevel after lift
do you have any picture?
canadian trucker is offline   Reply With Quote
Old 04-03-2013, 05:48 PM   #3
Pro Performance
Pro Performance's Avatar
The original springs on the truck might have settled over the years, so that 6" lift spring up front is compared to a brand new stock height spring (that hasn't settled or sagged). This is why you might have seen more lift than expected, over the 6". As for the rear, you are still using that old spring, so the block gave it exactly 6" of lift.
This could be why it happened... possibly???
Pro Performance is offline   Reply With Quote
Old 04-03-2013, 06:26 PM   #4
Gregsenne
So, while looking for a picture of my truck with the lift on it, I came across a picture of it before the lift. I guess I just never noticed the rear squat before the lift.
Think this is just caused by wear on the rear spring? Just seems an awful lot to drop. They must've dropped 4 inches from factory (more if this truck had any factory rake, not sure if they did tho)
After the lift: 35's with 6 in. suspension
Before the lift: 33's with stock half ton suspension
Old 04-03-2013, 06:37 PM   #5
Pro Performance
Could be the possibility.... I know it happens with coil springs. I think the truck looks good after the lift, and doesn't look like it has that much rake.
It looks as though the body sits level to the ground, and the difference you are seeing is just the fender well opening difference. The front opening is a tad higher than the rear.
Old 04-03-2013, 06:50 PM   #6
Gregsenne
Maybe its just me. Everyone else I mention it to says they didnt even notice the unlevelness. But it bugs the crap outta me! I mean, it is 5 inches! It does look like the body is level with the ground, but I think it's just the picture. It really is noticeable in person.
Thanks guys, I'm getting 3/4 ton springs anyways, we'll see how they do!
Old 04-03-2013, 06:59 PM   #7
Pro Performance
What are the measurements from the bottom of the body to the ground? For example, measure from the bottom of the front fender, and measure from the bedside (just in front of the wheel wheel) to the ground. Those measurements should be closer to each other.
Old 04-04-2013, 04:37 AM   #8
andrewmp6
Leaf springs do sag over time just like any other spring does.
Old 04-04-2013, 10:55 AM   #9
broey
Square
broey's Avatar
also, Isnt the rear fender shorter than the front fender?
Squarebody Syndicate
broey is offline   Reply With Quote
Old 04-08-2013, 10:15 AM   #10
mooseknuckles
mooseknuckles's Avatar
yep...so it's prob more like 3" difference....
mooseknuckles is offline   Reply With Quote
