![]() Join Date: Jan 2012
1961 Bubbletop
Done CLR and been buffing on rt side. Don't have it running yet it does crank over. Looks to only have 33000 miles. Hope to get it running and brakes and enjoy it this summer. Was last run in 1980....
Re: 1961 Bubbletop
Wow! Looks nice.
Success is not final, failure is not fatal: it is the courage to continue that counts. Winston Churchill DD 2000 Chevy Suburban 4x4/5.3 Vortec/4L60E/4:10s, 18" Escalade rims, Electric fans Project Dooley One-Ton 4x4 on 38.5s Corn-binder build |
Re: 1961 Bubbletop
Re: 1961 Bubbletop
That is a nice find for sure. Full marks on cleaning up the paint. Dont go any further tho. Sweet as is . Needs 8 ich steel weels and tiny hupcaps!
56 gmc 4X4 Cummins 5 spd 60F 70R 2005 Ram 3500 DRW cummins 4X4. 2006 Conolift 9/15. 2011 F 350 winter beater New 2018 ram 3500 drw 4x4. Makes my 2005 Look as if it's been running on 4 cyl since new ! My Build http://67-72chevytrucks.com/vboard/s...d.php?t=556908 |
Slots go on anything!
Re: 1961 Bubbletop
Great find. That's one of my favorites. I had a few of them when I was in high school/ college. It looks to be pretty solid from the pics.
Tot Roddin'
Re: 1961 Bubbletop
Love this car!!!
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
Re: 1961 Bubbletop
Thanks, just got home from the autofair.. Found a few needed parts. Hope to get the other side cleaned up and get the car running soon It is a pretty solid car,It will need lower 1/4's but that can wait. plan to drive it like it is....
Re: 1961 Bubbletop
That is a beautiful car!
1955.2 Chevy 3100, 6bt, Getrag G360 5-speed, NP205, Dana 60/70 - http://67-72chevytrucks.com/vboard/s...d.php?t=536540 1992 Chevy K1500 Silverado ECSB 1965 "Crewcab" Chevelle 300 Deluxe - soon to be LBZ Duramax/4L85E powered |
Re: 1961 Bubbletop
Great car!!! Just put somw steelies and caps and call it done!!
Posted via Mobile Device |
Re: 1961 Bubbletop
I have the orginal 14" steel wheels but it had full wheel covers. Also I got ir running today they had the firing order off on the dist cap!!!! Sounds really good and blowed about five pounds of debris out the tailpipe. Now on to the brakes and cooling hoses...
On the path to financial ruin!
![]() Join Date: Jan 2009
Re: 1961 Bubbletop
You lucky dog, you. I would kill for a 61 bubble top. Congrats!!
'72 Chevelle SS--4.0 Whipple LS7, T56 Magnum, 20X9/20X13 HRE 791R, 6-piston Baer brakes, IRS '68 SWB C10--LS3, TKO-600, 22x10/22x12 HRE 948R, C5 suspension, shockwaves, custom frame Ooh Wee's Makeover...http://67-72chevytrucks.com/vboard/s...d.php?t=376280 |
Re: 1961 Bubbletop
Got the 283 running the other day. It sounds great and does not smoke. About 5 pounds of acorns,rabbit pellets and debris came out the exhaust. Also scored this set of 15" Cragars at the salvage yard, They have rust but I think a better match compared to the 80's Camaro wheels....
Re: 1961 Bubbletop
That's great news!! I'm very jealous! The cravats are cool and era correct . Id still go with a steelie and poverty cap
Re: 1961 Bubbletop
I agree on the steelies and poverty caps. I will have to find some 15" steelies as I plan to install disk brakes on the front....
#15 |
Re: 1961 Bubbletop
Can you share how you buffed the old paint?
#16 |
Re: 1961 Bubbletop
I am by no means a expert at this but I figured I would give it a try. It looks a lot better but when you get up close it still has the cracks in the paint. I actually like the patina look I know some don't(namely the wife) she has laid claim to the car! Here is what I did. Purchased CLR cleaner at Lowe's CLR stands for Calcium Lime Rust. Poured some of cleaner in a bucket and took scotch bright pads dipped in the CLR and scuffed the rust and paint on the car. I did this outside and used a water hose to keep the car rinsed and wet. After I was done with that I took 800 grit wet sand paper and wet sanded the car. After I finished with the 800 grit I took 2000 grit and wet sanded the car again. Then I took a buffer and buffing compound and buff the car. I then used swirl remover compound and the buffer. Then I finished up by waxing the car. Now all I have to do is the other side.Thanks Daniel
#17 |
![]() Join Date: Jun 2012
Re: 1961 Bubbletop
Awesome car
United States Marine Corps 2000-2011 Iraq and Afghanistan veteran Just living life now and enjoying it and my wife, daughter and son ![]() |
#18 |
Re: 1961 Bubbletop
Those wheels look just fine. I like steelies and poverty caps too but you cant beat a junkyadr find . Please loose the whitewalls tho. I grew up around them . Make the hair on my neck stand up now. Thanks dad. Lol...... How did you come across this car ? Good story by chance ?
#19 | |
Re: 1961 Bubbletop
#20 |
Re: 1961 Bubbletop
That sure is a nice find. A friend of my dads has a 61 bubble . 348 tri power 4 spd. red with the white insert. Nice car. It's in the shed at his farm. I dont think he will ever restore it but it's not being neglected either. It gets driven a few miles a year. He bought it in the early 80's when they were cheap .
#21 |
Re: 1961 Bubbletop
Got to love those bubble tops! Nice ride!
Classic Trucks Link http://www.classictrucks.com/feature...uck/index.html 1958 GMC.Project Build http://67-72chevytrucks.com/vboard/s...d.php?t=162816 1966 Chevelle Build http://67-72chevytrucks.com/vboard/s...d.php?t=443576 Video http://www.youtube.com/watch?v=prrNKo8F7Zw#GU5U2spHI_4 |
