Old 04-04-2013, 12:53 PM   #1
Gigem
Gigem's Avatar
Question Help diagnosing electrical problem?
Truck has been back on the road for a few weeks. Basically everything is new - motor, trans, complete wiring harness, starter, alternator, battery, etc. Swapped in a used automatic column with tilt, to replace the old column I had when I had the manual trans...
Go to start it yesterday, and nothing. Not even a blip from the starter. Try it again, and it fires right up.
I am in a hurry for work, so I don't let it warm up as long as I should. Make it to the end of the street, and it dies. Go to restart, and nothing again. Dead as a doornail. Headlights work, but nothing that is "switched" power works. Won't start in Park or Neutral. Nothing at all. Get my wife to steer as I push it back into the driveway, and as I hit the end of the driveway it magically springs back to life. Power returns to AC. She hits the key and it fires right up!
I have checked all wires and cables, and everything is tight. I am thinking that the ignition switch in my used, eBay-special tilt column is going bad. Sound like a reasonable thought?
1972 GMC Sierra Grande (current truck)
1980 Chevy Stepside (gone)
1987 Chevy Blazer (gone)
1972 Chevelle SS Convertible (gone)
1973 Chevy Corvette (gone)
1967 Chevy Camaro (STOLEN!)
Gigem is offline   Reply With Quote
Old 04-04-2013, 01:42 PM   #2
rs74
rs74's Avatar
Re: Help diagnosing electrical problem?
Years ago in my cutlass I had a similar situation but with no restart. It end up being a bad starter solenoid or a burnt wire at the solenoid. I can't remember which.
Roy
85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818
1987 R10 shortie
rs74 is offline   Reply With Quote
Old 04-04-2013, 03:18 PM   #3
Jonboy
Slots go on anything!
could be a bad or misadjusted ignition switch. If you replace it, use a Delco part.
Jonboy is offline   Reply With Quote
Old 04-04-2013, 04:49 PM   #4
motornut
78K & 79C Jimmys
motornut's Avatar
i had a 86 Grand Prix that wouldn't start sometimes, finally fixed it but had to turn the colum back from around the dash area
NSS switch was outa wack
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 04-04-2013, 04:52 PM   #5
54Caddy
GM Addicted
54Caddy's Avatar
What year is the truck??
..Mac’s Garage..
73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd
My 73 GMC Truck Build Pic
2010 Silverado 4/6 on 24s
IG:MacsGarage
54Caddy is offline   Reply With Quote
Old 04-04-2013, 05:06 PM   #6
Gigem
Gigem's Avatar
1980 - the one in my signature. I need to take "after" pictures, now that I have completed a ton of work on it...
Old 04-05-2013, 07:25 AM   #7
durty harry
durty harry's Avatar
You might want to check the switch on your clutch
Scott
82 step side aka " Bouncy "
73 GMC
Long bed Vortec 5.7
durty harry is offline   Reply With Quote
