Old 04-04-2013, 09:43 PM   #1
wick22
headers for a sbc in tf truck
ive got a 57 truck with stock steering box and suspension
it has the tubular engine cross member with a sbc only accessory is a alternator
has anyone successfully installed off the shelf headers that fit decent
block huggers,shorties,long tubes anything?
if so brand and part number would be awesome as well as pics lol
thanks in advance any advice is apreciated
wick22 is offline   Reply With Quote
Old 04-05-2013, 09:55 AM   #2
Katrina/10
Katrina/10's Avatar
Re: headers for a sbc in tf truck
Block huggers were the only thing I could get to fit.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Katrina/10 is offline   Reply With Quote
Old 04-05-2013, 10:10 AM   #3
Denee007
Denee007's Avatar
Omg, I went through a difficult time with headers. I asked this question long ago and just had to go by the seat of my pants or skirt, lol. I started with some block huggers, then changed to some Chinese long tube headers that wound up being deformed and fought to get my money back from the vendor!, then bought some Hedman headers that I really like, didn't hang down as far as I would like, but they "feel" solid, not tinny like the Chinese stuff. You can see them on my build thread. I have the stock frame with the Saginaw steering box conversion and a th350 tranny,sbc engine, with crossmember removed However, I don't know if these would mesh with the factory steering/parking brake! quite a few variables to take in consideration.
dne'
'72 Ford Bronco project(July 17 2021-?)
https://67-72chevytrucks.com/vboard/...d.php?t=828015
59 Apache (sold 6-25-2021)
67 Ford Mustang (re-restored after Harvey)
1968 Jeep Cj5 (2-8-2020 to present)
1992 Jeep Yj (8-17-20 to present) (Jurassic build)
www.Classiccarsandtools.com
Denee007 is offline   Reply With Quote
Old 04-05-2013, 10:51 AM   #4
starterman99
starterman99's Avatar
Before I rebuilt my truck I had a set of hedman headers i got through summit.I had to dimmple one of the tubes to clear original steering box.The truck is a 57 original v8 but i used the tube type motot mount.sorry I dont have any pictures of that on computer.
1950 5 window
starterman99 is offline   Reply With Quote
Old 04-12-2013, 08:42 PM   #5
wick22
were they shorties, long tubes, block huggers?
Old 04-12-2013, 09:19 PM   #6
62lwbc10
I just posted the same question! Would be good to get some specific feedback. Thanks alot
62lwbc10 is offline   Reply With Quote
Old 04-12-2013, 09:39 PM   #7
Dan in Pasadena
Dan in Pasadena's Avatar
I'd love to answer questions but I can't cause I didn't install my headers, they were on the truck when I bought it.
Not sure you can see it in this photo but whoever installed them did have to put a small dent in one tube to make them fit.
I WANT to remove them to have them coated - but honestly? They may be paper thin and I'm afraid the bolts would snap off in the heads, then I'd be SCREWED. I've read all the things to use: heat cherry red, use 50/50 ATF & acetone, the candle trick, tighten before loosing, etc. ALL of them have their proponents and failure stories.
Dan in Pasadena is offline   Reply With Quote
Old 04-13-2013, 11:52 AM   #8
starterman99
The pair I used were long tube headers.I went and looked in my file and found the headman part number from summit hed-69260.I had to dimple tube on drivers side.Also had to notch out bottom of bellhousing cross member to clearance exhaust.
1950 5 window
