Old 04-04-2013, 09:55 PM   #1
RsOnSt
RsOnSt's Avatar
Question rain getting in the cab any ideas how to fix it?
I have a 79 c10 found water is getting into my cab through the seam under the cowl vent and I've sprayed two cans of undercoating on it to seal the seam and it works fine for a few days but the coating crack's and water finds its way back the cab anybody have this problem and what did you do to fix it
TEXAS BOYZ WITH CHEVY TOYZ
RsOnSt is offline   Reply With Quote
Old 04-04-2013, 10:10 PM   #2
motornut
78K & 79C Jimmys
motornut's Avatar
Re: rain getting in the cab any ideas how to fix it?
caulking or body sealer
how this side area?
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 04-05-2013, 02:56 AM   #3
1981Stepside
1981Stepside's Avatar
When I thought my kick panel vent was leaking water into the cab, it turned out to be the corner of the windshield. The bottom corners of the window frame are a common rot spot.
Proud UA member since 2009
My LT1 Silverado build-up: http://67-72chevytrucks.com/vboard/s...d.php?t=549660
Check out my new YouTube channel! - https://youtube.com/channel/UCXk5mZOQI1sEnu5bIkhe7fA
1981Stepside is offline   Reply With Quote
Old 04-05-2013, 10:12 AM   #4
bilfman
bilfman's Avatar
Use a tube of autobody seam sealer it that is the leak spot.
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205
1971 GMC 3/4 Ton 4X4
bilfman is offline   Reply With Quote
