04-05-2013, 12:42 PM | #1 |
Fabricate a custom tranny cross member?
Hey y'all - I'd like to build a custom tranny cross member for the TH350 in my '80 swb, 2 wheel drive. I know I can build it, I'm just not good with design work. Do any of you have a design for one of these for me to work off of or know of a design on the internet that is a good one to use?
My goal is to eliminate the stock cross member so my exhaust can be as even as possible on both sides. Any help would be great. Thanks guys!
Project: 1980 Chevy SWB DD: 1999 Chevy Tahoe, lifted on 33"s Toy: 1996 HD FLSTC, custom by me |
04-05-2013, 01:34 PM | #2 |
Re: Fabricate a custom tranny cross member?
this seemed like a huge pain in the ass to me when i had this idea for the same reason, an "X" pipe might be your best friend if you want to make your exhaust even and its much easier
04-05-2013, 02:36 PM | #3 |
just finished mine,find a 73-78 c-10 and cross members will work,installed my headers and hand an angle problem,and 78-up are for single exhaust installed the older cross member and all worked good
04-05-2013, 04:13 PM | #4 |
They sell them for about $80 ready to bolt up
2008 Silverado Z71 RCSB 1991 GMC Jimmy 4x4 1976 GMC Sierra C15 SWB |
04-05-2013, 07:05 PM | #5 |
I know the pieces fit
Do you have a link? I'm wanting to try a 3" exhaust.
04-05-2013, 08:00 PM | #6 |
MOTORHEAD!
www.performanceonline.com it says for 60-72, but apparently fits 73-87's.... just have to drill a few holes that don't line up. I'll be installing mine in a couple weeks.
82 GMC High Sierra VortecPro 496 12 Bolt, 3.42's AFR 265 Holley 850 Performer RPM Air Gap Hooker 2455's TCI Turbo 400 Super Street Fighter TRRC 12 Bolt Eaton Posi Mark Williams Axles Cal-Tracs Hoosier 30x10.5 Radial Slick Full weight long box pickup Current best- 11.33@117mph |
04-05-2013, 08:33 PM | #7 |
Someone linked this crossmember a week or two ago. Nice price at $65. Thank you sir.
http://www.performanceonline.com/196...N-CROSSMEMBER/ |
04-05-2013, 10:20 PM | #8 | |
http://*************/crossmembers/63...on-crossmember >>>>>>>>>>> put thorbros dot com where the asterisks are in address above....sensorS no likey LOL <<<<<<<< $69.99 here it is mounted on a 1984
04-10-2013, 10:07 AM | #10 | |
Roy 85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818 1987 R10 shortie |
04-06-2013, 07:23 AM | #11 |
Im not sure, these pics are from a member here baclay9
04-06-2013, 09:18 PM | #12 |
That's the one I remember seeing. Thank you sir.
04-06-2013, 12:15 PM | #13 |
Thanks guys - great info.
04-06-2013, 07:36 PM | #14 |
I used this TransAdapt drop crossmember. The drop allows you have room for your exhaust. That straight crossmember above will be in the way if you want to tuck your exhaust.
Part #6559 Posted via Mobile Device
04-06-2013, 10:31 PM | #15 | |
04-06-2013, 10:46 PM | #16 |
Ah chit. I bought one this morning, I thought it mounted high in the frame rails.
04-06-2013, 10:42 PM | #17 |
At the body shop.
Early 3/4 ton x member. Notch the center clears 3" dual on my 73
" That didnt make it any newer " " Dont antique the equipment " |
04-06-2013, 10:46 PM | #18 |
At the body shop.
04-06-2013, 11:33 PM | #19 |
Those look like spintech mufflers mmmmmmm
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
04-07-2013, 01:54 AM | #20 |
Only issue I have with the single tube crossmembers like the straight one and mine too is that they don't tie the top and bottom of the frame together. If you look at KQQL IT's early factory Xmember it is 3 pieces and hits the frame in 4 places. I modified mine to bolt into the bottom and side of the frame. My 2€
04-07-2013, 06:00 PM | #21 | |
At the body shop.
When I drooped the t400 onto it the rail rolled in a good bit. So I put them back in. Posted via Mobile Device
04-07-2013, 07:09 AM | #22 |
BAD BOW-Silverado XST
PM your email address. I have a custom made crossmember. It's made of 2" tube steel. It's made with dual humps for exhaust routing. Works great. The exhaust it tucked up into the underside.
04-10-2013, 09:48 AM | #23 |
Who made your crossmember. I would like to be able to run a x-pipe above the crossmember if possible. Someone post a link to a site that made them for LS conversions but can not remember the site now. Although I think the exhaust ran under the crossmember.
04-10-2013, 10:04 AM | #24 |
I bought the one pictured above thinking it mounted high in the frame. I can't use it with my long tube headers. 20% off sale if anyone is interested.
04-10-2013, 10:29 AM | #25 |
Are you talking about the one from trans adapt or thors bros. There is also one from performance online but there is no pic of it.
