04-06-2013, 10:24 AM | #1 |
What year is my daughter's truck?
My daughter bought my brother's pickup from him. He swears up and down that it is an 1965 Chevy. He has even added a drivers door, hood, and grill from a 65'. Title wise it shows to be a 1960. The vin # on the title is 0C363K106750. I found another number on the frame 6Z107220. Any ideas? Thanks
04-06-2013, 10:35 AM | #2 |
Who Me?
Re: What year is my daughter's truck?
Its definitely not a 1960. I would say its between 64-66, but on the drivers side it has two different badges on it.. There was a different one for each year.
Steve 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
04-06-2013, 10:43 AM | #3 |
Drivers side of the frame just about even with the door, there will be the vin number stamped into the frame, see if it matches the registration, you will probably need sand paper to clean it to be able to read it.
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
04-06-2013, 10:48 AM | #4 |
Ok, I was wrong in original post. The fenders, the drivers door and the grill came off of a for sure 65. I went back and looked on my facebook messages to see exactly what he said. Does that help any?
04-06-2013, 10:58 AM | #5 |
That is not a knee knocker cab my friend so it is definitely not a pre 1963. 1965 sounds about right. Is that cab and hood original? If so, they're both tell tale signs of being mid 60's. The 60-61 and some 62's had the "bug eye" hoods still. They were all gone by 1963. That cab is 64-66 for sure. The last year of the knee knocker trucks was 1963. Yours is not one. Hope this helps.
Posted via Mobile Device |
04-06-2013, 11:00 AM | #6 |
it is definitely a 64, 65, or a 66 based on the windsheild being flat, not wraparound
the VIN will tell you, for 1964 the first digit in the VIN will be a 4, for the 65 or 66 the 5th digit in the VIN will be a 5 or a 6 respectively. The VIn will be on the frame as noted in a previous post, and I can tell you that at least for the 66 there is a VIN plate on the cab, with the door open it would be riveted to the top of the door opening. Quite possible that these numbers don't match if it has ever been restored, or modified.
Craigerrr My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709 |
04-06-2013, 11:03 AM | #7 |
I think that reverse lights were standard in '66? Optional in '65 and maybe '64? Like Rich was saying. Drivers side, top of frame, about even with the front of the engine. The #s are there. 60-63 had the "knee knocker" or dog leg at the sides of the windshield. Yours is definitely a '64-'66
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
04-06-2013, 01:14 PM | #8 | |
Sold the 63 and have a 68 now. 63 SWB C10 LT1/4L60E, PS, PB, Disk Brakes, CPP 4" drop coil rear, 2.5" drop spindle w/ 1" drop coil. slotted rotors, front and rear sway bars. 18"x8" Cragar SS w/ 245/45R18 http://67-72chevytrucks.com/vboard/s...d.php?t=544174 |
04-06-2013, 01:33 PM | #9 |
yeah the 6Z107220 says the frame (and the rest of the truck except the vin plate) are 1966.
I have seen lots of spot welded vin tags, the original method of attachment and the placement let them get knocked off pretty easily. the spot welds held them on once they had been knocked off. someone probably had two trucks and one vin tag at some point.
04-06-2013, 02:08 PM | #10 |
reverse lights became standard equipment in 66, but were an available option prior to that, so the fact that there are reverse lights doesn't really mean anything,
04-06-2013, 02:15 PM | #11 |
Yes Sir
LIFE IS SHORT HAVE FUN |
04-06-2013, 04:51 PM | #12 |
My guess: The body is a '64. Somebody changed out the cowl extensions to a pair from a '65. The VIN# is jiving with the year of the truck.
Check out my latest endeavor: https://roundsixpod.com My build threads: '55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512 '64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527 |
04-06-2013, 06:02 PM | #13 |
Who Me?
Nice looking truck!
04-06-2013, 06:41 PM | #14 |
I found some numbers on the side of the frame, not the top. Took pics of the numbers on the top of the frame by the engine. the last one is the vin tag off of the top of the drivers door frame.
04-06-2013, 08:21 PM | #15 |
I could be wrong, but I think the VIN tag is from a 1960 1 ton cab and chassis, built in Kansas City.
04-06-2013, 08:42 PM | #16 |
I would suspect a vin tag swap happened at some time. 1960 vin on a 64-66 cab and a 66 frame.
1963 Chevy stepside 327 1965 Chevy swb 383 1996 Mystic Mustang Cobra 2009 Pontiac G8 GXP 415hp/415tq 6speed |
04-06-2013, 09:08 PM | #17 |
Moderator
Those don't look like original VIN rivets, either.
04-06-2013, 09:21 PM | #18 |
Vin plate switched for sure. Do you have a registration or pink slip that shows which vin# it's registered to?
Name: Rich Current Ride: 1964 C-10 Short Fleetside Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe Past GM Trucks: 1959 GMC short stepside 1968 GMC short stepside-4x4 1973 Chevy short stepside 1989 Chevy short fleetside-reg cab 1993 Chevy short fleetside-Xcab 2002 Chevy short fleetside-Xcab Save the dinosaurs, use synthetic oil. |
04-07-2013, 12:41 AM | #19 | ||
60-66 Nut
I agree with these guys.
Someone has switched the VIN tag on the cab with one that they had a title for, which was a 1960 C30 cab and chassis with a 133" wheelbase. The cab and the rest of the body is consistant with a '64-5-6 truck, and your frame is definitely a '66. Hopefully your local DMV doesn't want to do a VIN inspection....... Quote:
04-06-2013, 09:33 PM | #20 |
Anything from 63 or earlier would have the wrap around windshield. Since it doesn't, then it's a 64, 65, or 66 cab. The cab might have 2 little holes at the top of the firewall for the tubing for windshield wiper fluid. See photo of my 66. I think that was only available in 66.
A 62 frame has a "V" reinforcement under the bed - see photo.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild. |
04-07-2013, 07:00 AM | #21 |
Thank you for all the help. We live in Texas and hopefully as long as the truck stays titled in Texas we should be good. So, now I guess the new big question is: What year do we buy parts for? Are most parts interchangeable from the 64-66? I don't really want Britnie to have to have a henze 57 truck. She's young and not knowledgeable enough to keep track of what part belongs to what year.
04-08-2013, 12:37 AM | #22 | |
60-66 Nut
Before it's done, you will likely have parts from different years of trucks or cars. It is very simple to keep track of. Just make a master list in a notebook.
04-15-2013, 10:50 AM | #23 |
The badge on the fender extention is a 65 and the badge on the fender is a 64.
The reverse light indicate a 66. Best way to tell what year it is, is to look on the drivers side kick plate, just before the vent door, for the available motors for that year. If the 327 V8 was not an option, then it is not a 66. If the 153 4 cyl is an option it would be a 64. 65 I am not sure. Does it have a 6 cylinder or a V8? |
04-16-2013, 06:52 PM | #24 | |
Currently, it has a 305 v8 out of a 1984 chevy scottsdale. I guess my brother changed it out.
04-16-2013, 06:57 PM | #25 |
Here are some more pictures. No other new information to go off of.
